Cypress技术论坛
直播中
曹珉
7年用户 203经验值
私信 关注
[问答]
ADC转换的触发点永不清零
初始信息:
. ADC扫描4个通道,一个具有单范围检测,2个DIF模式
由软件(ADCJSTARCONV…)触发的转换4个采样平均在所有通道上
在转换之间,使用API(EEPROMYORDION…)将Flash写入单个缓冲区(未禁用中断)
当进入内文阅读AdcSARSa SARIONITRYRG,并在结尾写Reg
经过几分钟的ADC执行触发中断(我可以聊天这一点)中断中断射击了。重置是必需的,故事重演。
转换的触发点是永不清零(根据TRM应该由硬件清除)。在运行期间没有修改内向量表。
我已经联系支持的情况下,但不动的东西了。
有什么想法吗?
鲍勃
以上来自于百度翻译
     以下为原文
  Initial info:
    . ADC scanns 4 channels, one with single range detect, 2 with dif mode
    .conversion triggered by software (ADC_startConv...) 4 sample averaging on all channels
    .between conversions flash is written using API (EEPROM_WRITE..) into a single buffer ( interrupts not disabled)
    .when entering intr read ADCSAR_SAR_INTR_REG, and written reg at the end
    After few minutes of adc performace triggering interrups ( I can chatch this point) the interrupts stop firing anymore. reset is required and story repeats.
    Conversion trigger bit is never cleared (acc. to TRM should be cleared by hardware). intr vector table is not modified during run.
    I'm already contacting support case, but does not move thing forward.
    Any ideas?
    bob
回帖(2)
王琳
2019-7-18 12:06:56
哦,忘记了:
如果可能的话,请您创建一个工作区包并在这里上传项目,以便我们都可以查看或重现错误。
鲍勃
以上来自于百度翻译
     以下为原文
  Oh, forgotten:
    When possible, will you please create a Workspace Bundle and upload the project here, so that we all can have a look at or even reproduce the error.
    Bob
举报
杨军
2019-7-18 12:22:34
这是一个长镜头,在ISR中修改的任何变量都不被声明为易失性?
关于挥发性的一些附加信息
HTTP://E.WiKiTo.Org/Wik/ValueLy变量
HTTP://www. BARRGROUP.COM/EnguldDeSts/Ho-to/C挥发关键字
问候,Dana。
以上来自于百度翻译
     以下为原文
  This is a longshot, any variables modified in ISR not declared as volatile ?
    Some additional info on volatile -
    http://en.wikipedia.org/wiki/Volatile_variable
     http://www.barrgroup.com/Embedded-Systems/How-To/C-Volatile-Keyword
    Regards, Dana.
举报
更多回帖
