ST意法半导体
直播中
李耀鑫
8年用户 210经验值
私信 关注
[问答]
我需要使用uart2接收带中断的数据吗?
您好我是端口uart2轮询接收来自超级终端的数据没关系。但我需要使用uart2接收带中断的数据?
tiM3_DeInit();
TIM3_TimeBaseInit(TIM3_PRESCALER_1,0xFFFF);
TIM3_ITConfig(TIM3_IT_UPDATE,ENABLE);
enableInterrupts();
GPIO_Init(GPIOD,0x01,GPIO_MODE_OUT_PP_LOW_FAST);
CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);
UART2_DeInit();
UART2_Init((u32)9600,UART2_WORDLENGTH_8D,UART2_STOPBITS_1,UART2_PARITY_NO,UART2_SYNCMODE_CLOCK_DISABLE,UART2_MODE_TXRX_ENABLE);
UART2_ClearITPendingBit(UART2_IT_RXNE);
UART2_ITConfig(UART2_IT_IDLE,ENABLE);
这段代码不正确我不知道使用功能,看看注册请帮帮我
以上来自于谷歌翻译
以下为原文
Hello i'm port uart2 polling receive data from hyperterminal it's ok. but i need use uart2 receive data with interrupt?
   TIM3_DeInit();
    TIM3_ITConfig(TIM3_IT_UPDATE, ENABLE);
     enableInterrupts();
     GPIO_Init(GPIOD, 0x01 , GPIO_MODE_OUT_PP_LOW_FAST);
     UART2_DeInit();
     UART2_Init((u32)9600, UART2_WORDLENGTH_8D,    UART2_STOPBITS_1, UART2_PARITY_NO, UART2_SYNCMODE_CLOCK_DISABLE, UART2_MODE_TXRX_ENABLE);
     UART2_ITConfig(UART2_IT_IDLE, ENABLE);
this code incorrect i don't know use function and see a register please help me
回帖(3)
欧丽娜
2019-7-16 10:19:08
TIM3_DeInit();
enableInterrupts();
UART2_DeInit();
UART2_ITConfig(UART2_IT_RXNE_OR,ENABLE);
以上来自于谷歌翻译
以下为原文
TIM3_DeInit();
enableInterrupts();
UART2_DeInit();
UART2_ITConfig(UART2_IT_RXNE_OR, ENABLE);
举报
廖阿朋
2019-7-16 10:25:45
在从UART2中断例程读取一个字节后,我是否需要使用UART2_ClearITPendingBit()函数,或者自己的读取操作清除了挂起的位RXNE,我有疑问。我无法从RM0016参考手册中找到此信息。
我正在使用的代码:
#ifdef _COSMIC_
@far @interrupt void UART2_RX_IRQHandler(void)
#else / * _RAISONANCE_ * /
void UART2_RX_IRQHandler(void)中断21
#endif / * _COSMIC_ * /
 //从接收数据寄存器中读取一个字节
 RxBuffer [RxCounter ++] = UART2_ReceiveData8();
 如果(
RxCounter == 128)
 RxCounter = 0;
以上来自于谷歌翻译
以下为原文
I´m in doubt if I need to use the UART2_ClearITPendingBit() function after read a byte from UART2 Interruption routine, or the own read action clears the pending bit RXNE. I couldn´t find this information from RM0016 reference manual.
The code I´m using:
#ifdef _COSMIC_
#else /* _RAISONANCE_ */
void UART2_RX_IRQHandler(void) interrupt 21
#endif /* _COSMIC_ */
  // Read one byte from the receive data register
  RxBuffer[RxCounter++] = UART2_ReceiveData8();
  if(
RxCounter==128)
   RxCounter=0;
举报
廖阿朋
2019-7-16 10:45:18
我已经在这里测试过,这个功能没有必要。
以上来自于谷歌翻译
以下为原文
I´ve already tested here,  that function is not necessary.
举报
更多回帖
