问候一个,这是我的第一篇文章,所以我会努力使它成为一个好的。我是在菲尼克斯的精密测量实验室工作的国防部承包商。
我有一个3458A,我正在升级03458-91000 A2板,取代目前安装的03458-66502板。
据我所知,这将为我的3458A提供4ppm的Opt 002 Hi-Stability Reference。
换掉
电路板并预热后,我启动了ACAL ALL。
在ACAL的AC部分期间,我收到此错误:“204,HARDWARE FAILURE,AC VOS DAC CONVERGENCE:1837035519。”
在做了研究之后,我发现这个错误(204)与我刚刚安装的卡有关。
我仔细检查了所有连接,重新运行ACAL并得到了同样的错误。
我把旧卡放回去,运行ACAL,它工作正常。
我的问题是;
我错过了什么吗?
是否需要将软件或其他类型的更新输入到设备中,或者我的91000 A2板是否有用?请提前感谢您的帮助。
以上来自于谷歌翻译
以下为原文
Gree
tings one and all,
This is my first post, so I'll try to make it a good one.
I am a DoD contractor working at a precision measurement lab in Phoenix. I have a 3458A that I am upgrading with a 03458-91000 A2 board, replacing the 03458-66502 board currently installed. It is my understanding that this will give my 3458A the Opt 002 Hi-Stability Reference, 4ppm. After swapping out the board and w
ARMing up the unit, I initiated ACAL ALL. During the AC portion of the ACAL, I receive this error: "204, HARDWARE FAILURE, AC VOS DAC CONVERGENCE: 1837035519." After doing research, I found that this error (204) pertains to the card I just installed. I double-checked all the connections, re-ran ACAL and got the same error. I put the old card back in, ran ACAL and it worked fine. My question is; am I missing something? Is there a software or some other kind of update that needs to be input into the unit, or is my 91000 A2 board a dud?
Thanks in advance for your help.
