Microchip
直播中
林森
8年用户 139经验值
私信 关注
[问答]
如何找出ICSP是否有通用的布局?
我试图找出ICSP是否有通用的布局。我在DIP包里有PIC12F675和PIC10F200 8引脚IC。我看了引脚说明,看起来我必须制作两个独立的PCBS来编程,除非有一个通用板,它们可以同时安装在和b上。可以编程。
以上来自于百度翻译
      以下为原文
    I am trying to find out if there is a universal layout for the ICSP.
I have PIC12F675 and PIC10F200 8 pin IC's in the DIP package.
I looked at the pin descriptions and it looks like I would have to make 2 separate PCBS for programming, unless there is a universal board that they can both fit on and both be programmed on.
回帖(3)
李天竹
2019-7-11 09:13:43
PIC10是一个6引脚PIC,所以它的8引脚DIP ValANSAS具有2个引脚为NC PIC12的不同布局是一个8位PIC。它具有与14位和20位PIC16S/PIC18S相同的布局,只有极少数例外。
以上来自于百度翻译
      以下为原文
    PIC10 is a 6-pin PIC, so its 8-pin DIP variant has a different layout with 2 pins being NC.
PIC12 is an 8-bit PIC. It has the same layout as 14-bit and 20-bit PIC16s/PIC18s with very few exceptions.
举报
韩禹
2019-7-11 09:24:52
非常感谢你
以上来自于百度翻译
      以下为原文
    Thank you very much
举报
李梅
2019-7-11 09:40:57
你的意思是:PIC12是一个8针PIC。它具有与14引脚和20引脚PIC16S/PIC18S相同的布局,只有极少数例外。
以上来自于百度翻译
      以下为原文
You mean:
PIC12 is an 8-pin PIC. It has the same layout as 14-pin and 20-pin PIC16s/PIC18s with very few exceptions.
举报
更多回帖
