是德科技
直播中
刘建国
8年用户 204经验值
私信 关注
[问答]
如何用SCPI命令启动用户平面度校准?
您好,我正在使用SCPI命令远程控制E8527D信号发生器。
我正在尝试使用SCPI创建和应用平坦度校正表,类似于信号发生器用户手册第76-77页(附件)中的步骤。
我找到了为Power Meter配置系统的命令,但我找不到使用Power Meter启动用户平坦度校准的命令。
手动,命令是:幅度 - >用户平坦度 - >执行校准是否有人知道SCPI命令启动此校准?
此致,阿什利
以上来自于谷歌翻译
     以下为原文
  Hello,
I am using SCPI commands to remotely control an E8527D Signal Generator. I am attempting to create and apply a Flatness Correction table using SCPI, analogously to the procedure in the Signal Generator User's Manual pp 76-77 (attached). I found the commands to configure the system for the Power Meter, but I cannot find the command to initiate the User Flatness Calibration using the Power Meter.
Manually, the command is:
Amplitude --> User Flatness --> Do Cal
Does anyone know the SCPI command to initiate this calibration?
Regards,
Ashley
附件
回帖(2)
刘建国
2019-7-9 09:06:29
嗨,谢谢你的回复。
我认为我发现的是,不可能命令引导用户平坦度校正。
因此,我确实通过自己控制功率计并创建自己的校正表来实现我的校正程序,然后像示例中那样加载该表。
我认为让SCPI命令设置并命令引导平直度校准会很方便。
以上来自于谷歌翻译
     以下为原文
  Hi, thanks for your response. I think what I've discovered is that it's not possible to command a guided user flatness correction. So instead, I did implement my correction routine by controlling the Power Meter myself and creating my own correction table, then loading that table as in the example. I do think it would be convenient to have SCPI commands to set up and command the guided Flatness Calibration instead.
举报
李微波
2019-7-9 09:23:26
我有同样的问题。
您是否能够弄清楚如何通过SCPI命令Do Cal?
以上来自于谷歌翻译
     以下为原文
  I have the SAME EXACT question. Were you ever able to figure out how to command Do Cal via SCPI?
举报
更多回帖
