你好,
我正在进行一个项目,FX3尝试使用图像传感器MT9V034获得分辨率为640×120的实时视频AT240 FPS。
我已经检查了FX3(5Gbps)、UVC(128Mbps用于USB 3.0)和图像传感器(27 Mbps)的带宽,并且它们都支持在该分辨率下的帧速率(640×120×1×240=18.43Mbps,因为传感器输出是单色的)。
我想知道这是否意味着整个系统可以正常工作在240英尺?
最好的,
埃里克
以上来自于百度翻译
以下为原文
Hi,
I am working on a project with FX3 trying to obtain live video at 240 fps with resolu
tion 640 x 120 using image sensor MT9V034.
I have checked the bandwidth of FX3 (5Gbps), UVC (128Mbps for USB3.0) and the image sensor (27Mbps) and they all support the frame rates at this resolution (640 x 120 x 1 x 240 = 18.43Mbps since the sensor output is monochrome).
I am wondering does this mean the whole system can work properly at 240 fps?
Best,
Eric
