赛灵思
直播中
张建华
7年用户 193经验值
私信 关注
[问答]
怎么使用现有的400A比特流从400A迁移到400AN
大家好
我们正在考虑用400AN替换400A。
从我收集的内容来看,我所要做的就是将新400AN的M0,1,2引脚设置为从内部SPI FLASH加载,我们可以在新的400AN中使用旧的现有400A比特流。
这看起来好得令人难以置信。
有人真的这样做过吗?
有没有人尝试将400A比特流写入具有内部FLASH的equilavent 400AN设备而没有问题?
如果这是这些设备的标准,我们将非常高兴。
干杯,
史蒂夫
以上来自于谷歌翻译
以下为原文
Hi all
We are considering replacing our 400A's with 400AN's. From what I gather, all i have to do is set the M0,1,2 pins of the new 400AN's to load from internal SPI FLASH, and we can use our old existing 400A bitstreams in the new 400AN's. This seems too good to be true. Has anyone actually done this? Has anyone tried writing a 400A bitstream into an equilavent 400AN device with internal FLASH without problems?
If this is the norm for these devices, we'll be very happy.
cheers,
Steve
回帖(1)
潘晶燕
2019-7-1 10:03:30
史蒂夫,
是。
它们是完全相同的FPGA器件芯片。
AN上堆叠有闪光灯芯片。
您需要使用正确的选项设置正确编程闪光灯。
因此,它与您可能使用的字节文件不完全相同,因为您之前所拥有的编程为与堆叠模具闪存部件不同的东西。
但是,真正的好消息是,您不必触摸已经正在工作的设计,并且bitgen使用相同的ncd文件,因此不会出现因为某些内容发生变化而弹出的“新”问题(实际的位数)
FPGA完全相同)。
Austin Lesea主要工程师Xilinx San Jose
以上来自于谷歌翻译
以下为原文
Steve,
Yes.  They are exactly the same FPGA device die.  The AN has a flash die stacked on it.
You do need to program the flash properly, with the right options set.  So it isn't axactly the same bitfile as you may have used, as what you had before was programmed into something different from the stacked die flash part.
But, the real good news, is that you do not have to touch your already working design, and the same ncd file is used by bitgen, so there will be no "new" issues that pop up because something changed (the actual bits in the FPGA are identical).
Austin Lesea
Principal Engineer
Xilinx San Jose
举报
更多回帖
