Microchip
直播中
刘玉兰
7年用户 997经验值
私信 关注
[问答]
请问有没有更快的方法返回Make和Build?
IDE中的“制作和程序设备主项目”按钮被淡出。我可以通过尝试用没有连接到IDC3的程序来触发这个条件。在点击“Debug Main Project”按钮之后,这个选项会返回。除了启动调试会话,有没有更快的方法返回Make和Build?生出效应意味着什么?IDE的用户指南并没有告诉我关于这个条件的任何东西。
以上来自于百度翻译
      以下为原文
    The "Make and Program Device Main Project" button is greyed out in the IDE. I can trigger this condition by trying to program with nothing connected to the IDC3. The option comes back after clicking the "Debug Main Project" button.
Is there a faster way to being back Make and Build other than starting a debug session?
What does the geyed out effect mean?
The IDE's user guide doesn't say anything about this condition from what I can tell.
   Attached Image(s)
回帖(5)
tijing忽忽
2019-6-28 07:43:52
如果您没有连接到调试/编程工具的图片,那么“Make and Program”选项没有多大意义,没有任何可编程的。
以上来自于百度翻译
      以下为原文
If you have no pic connected to the debug/programmer tool then the "Make and Program" option does not make much sense, there is nothing to program.
举报
吕聪
2019-6-28 08:39:34
当我按下“生成和编程”按钮时,我得到以下信息:“未找到目标设备(未能检测到目标电压VDD)”。您必须连接到目标设备才能使用ICD3。
以上来自于百度翻译
      以下为原文
    I get the following message when I press the Make and Program button:
'Target device was not found (could not detect target voltage VDD). You must connect to a target device to use ICD3.'
The project builds, the IDE connects to the ICD3, fails to find a target, and the buttons return to 'active'
MPLABX 3.40, XC16 1.26,
举报
成尔秩
2019-6-28 08:58:04
在MPLABX V3.40中,按钮不会变灰。我用的是V3.35。升级使问题消失了。它一定是一个微芯片固定的错误。
以上来自于百度翻译
      以下为原文
    The buttons do not become greyed out in MPLABX v3.40. I was using v3.35. Upgrading makes the problem go away. It must've been a bug that Microchip fixed.
Thanks vjasinski.
举报
李为敏
2019-6-28 09:31:10
灰色的制作和制作和程序设备按钮指示你处于调试模式。如果您退出调试模式,MICKAK和程序设备按钮现在应该是可点击的。
以上来自于百度翻译
      以下为原文
    Greyed out Make and Make and Program Device buttons indicates that you are in Debug mode. If you exit Debug Mode, the Make and Program Device buttons should now be clickable.
举报
更多回帖
