> {quote:title = miyamky写道:} {quote}>我不能超过我们使用的频率,但步长为1MHz。
我们从PRESET开始,然后RF开机,然后设置静态功率值,然后我们循环频率步进。
我不知道LIST模式是什么。
首先找出你使用的模式:: FREQ:MODE?
这些是您正在使用的命令吗?
:FREQ [:CW] nxHz'这将输出频率设置为CW(或固定),您也可以使用(:FREQ:FIX nxHz):FREQ [:CW]:STEP nxHz'这设置步长,但不是
改变频率:FREQ [:CW] UP'这使频率增加步长,:FREQ [:CW] DOWN递减步长列表模式将类似于以下之一:FREQ:MODE LIST:LIST:TYPE LIST
:LIST:FREQ 1GHZ,2GHZ,4GHZ,8GHZ'任意列表的示例:LIST:DIR UP:SWE:DWEL n:SWE:POIN n'这必须匹配列表中的频率数或:FREQ:MODE LIST:LIST:
TYPE STEP:FREQ:STAR nxHZ:FREQ:STOP nxHZ:LIST:DIR DOWN'如果需要,反转发电机步进扫描方向:SWE:POIN n'这将根据(停止 - 启动)/(npoints)设置步长
-1):SWE:DWEL n这些应该让你开始,我不经常使用列表模式,但它最重要的是非常有用。
Spacecase
以上来自于谷歌翻译
以下为原文
> {quote:title=miyamky wrote:}{quote}
> I can't go over the frequencies we use but the step size is 1MHz. We start w/ PRESET, then RF power ON, then set a static power value, then we loop on frequency stepping. I have no idea what LIST mode is.
First find out what mode you are in with:
:FREQ:MODE?
Are These the commands you are using?
:FREQ[:CW] nxHz ' This sets the output frequency to CW (or Fixed), you could also use (:FREQ:FIX nxHz)
:FREQ[:CW]:STEP nxHz ' This sets the Step size, but does NOT change the frequency
:FREQ[:CW] UP ' This increments the frequency by the step size, :FREQ[:CW] DOWN decrements by step size
List Mode would be something like one of these
:FREQ:MODE LIST
:LIST:TYPE LIST
:LIST:FREQ 1GHZ,2GHZ,4GHZ,8GHZ ' example of an arbitrary list
:LIST:DIR UP
:SWE:DWEL n
:SWE:POIN n ' This must match number of frequencies in list
or
:FREQ:MODE LIST
:LIST:TYPE STEP
:FREQ:STAR nxHZ
:FREQ:STOP nxHZ
:LIST:DIR DOWN ' Reverse the generator step sweep direction, if you want
:SWE:POIN n ' This sets the step size based on, (stop-start)/(npoints-1)
:SWE:DWEL n
These should get you started, I don't use list mode that often, but it the top one is very useful.
Spacecase
我不知道LIST模式是什么。
这些是您正在使用的命令吗?
Spacecase
以上来自于谷歌翻译
以下为原文
:FREQ:MODE?
:FREQ:MODE LIST
:LIST:TYPE LIST
:LIST:DIR UP
:SWE:DWEL n
or
:FREQ:MODE LIST
:LIST:TYPE STEP
:FREQ:STAR nxHZ
:FREQ:STOP nxHZ
:SWE:DWEL n
Spacecase
举报
