赛灵思
直播中
李慧
8年用户 971经验值
私信 关注
[问答]
为何斯巴达3A dsp 3400套件无法打开?
各位大家好,我购买了斯巴达3A dsp 3400套件。该CD带有内容演示,当我打开它时:D: ... 演示 EDK  EDK_Demonstrations  Camar
出现a_Frame_Buffer_Demothe错误:错误:EDK  - 已安装的EDK工具版本为12.1,而项目是使用版本14.2创建的。我尝试在14.2中打开它,但出现了多个错误:ERROR:EDK:4110  -  IPNAME:xps_gpio,
实例:LEDs_8Bit  - 在任何存储库中找不到pcore'xps_gpio_v1_00_a'的MPD  -  D: BGS  Demonstrations  EDK  EDK_Demonstrations  Camera_Frame_Buffer_Demo  system.mhs第207行错误:EDK:4110  -  IPNAME:xps_gpio,INSTANCE:LED_8Bit
- 无法在任何存储库中找到pcore'xps_gpio_v1_00_a'的MPD  -  D: BGS  Demonstrations  EDK  EDK_Demonstrations  Camera_Frame_Buffer_Demo  system.mhs第207行错误:EDK:4110  -  IPNAME:xps_gpio,INSTANCE:Push_Buttons_Position  - 找不到
任何存储库中的pcore'xps_gpio_v1_00_a'的MPD  -  D: BGS  Demonstrations  EDK  EDK_Demonstrations  Camera_Frame_Buffer_Demo  system.mhs第220行错误:EDK:4110  -  IPNAME:xps_gpio,INSTANCE:DIP_Switches_8Bit  - 无法找到MPD
pcore'xps_gpio_v1_0
任何存储库中的0_a' -  D: BGS  Demonstrations  EDK  EDK_Demonstrations  Camera_Frame_Buffer_Demo  system.mhs第233行错误:EDK:4110  -  IPNAME:clock_generator,INSTANCE:clock_generator_0  - 无法找到pcore'clock_generator_v1_00_a'的MPD
任何存储库 -  D: BGS  Demonstrations  EDK  EDK_Demonstrations  Camera_Frame_Buffer_Demo  system.mhs第262行错误:EDK:4110  -  IPNAME:mpmc,INSTANCE:mpmc_0  - 找不到任何一个pcore'mpmc_v4_03_a'的MPD
存储库 -  D: BGS  Demonstrations  EDK  EDK_Demonstrations  Camera_Frame_Buffer_Demo  system.mhs第389行错误:EDK:4111  -  IPNAME:xps_gpio,INSTANCE:LED_8Bit  - 无法找到pcore的MPD  -  D: BGS  Demonstrations  EDK
EDK_Demonstrations  Camera_Frame_Buffer_Demo  system.mhs第207行错误:EDK:4111  -  IPNAME:xps_gpio,INSTANCE:Push_Buttons_Position  - 无法找到pcore的MPD  -  D: BGS  Demonstrations  EDK  EDK_Demonstrations  Camera_Frame_Buffer_Demo  system.mhs第220行错误:
DIP_Switches_8Bit  - 无法找到pcore的MPD  -  D: BGS  Demonstrations  EDK  EDK_Demonstrations  Camera_Frame_Buffer_Demo  system.mhs第233行ERROR:EDK:4111  -  IPNAME:clock_generator,INSTANCE:clock_generator_0  - 无法找到pcore的MPD  -  D:
BGS  Demonstrations  EDK  EDK_Demonstrations  Camera_Frame_Buffer_Demo  system.mhs第262行错误:EDK:4111  -  IPNAME:mpmc,INSTANCE:mpmc_0  - 无法找到pcore的MPD  -  D: BGS  Demonstrations  EDK  EDK_Demonstrations  Camera_Frame_Buffer_Demo
system.mhs第389行,当我尝试从revup打开(system.xmp)时,它无法打开。我可以打开它并实现斯巴达进行测试。请给我你的帮助。
以上来自于谷歌翻译
以下为原文
Hi everybody,
I purchased spartan 3A dsp 3400 kit .
The CD came with it content demonstrations and when I opened it
D:...DemonstrationsEDKEDK_DemonstrationsCamar
a_Frame_Buffer_Demo
the error appeared was that:
Error:EDK - The installed version of EDK tools is 12.1 , while project was created with version 14.2.
I try to opened it in 14.2 ,but multiple error appeared:
ERROR:EDK:4110 - IPNAME: xps_gpio, INSTANCE: LEDs_8Bit - cannot find MPD for the pcore 'xps_gpio_v1_00_a' in any of the repositories - D:BGSDemonstrationsEDKEDK_DemonstrationsCamera_Frame_Buffer_Demosystem.mhs line 207
ERROR:EDK:4110 - IPNAME: xps_gpio, INSTANCE: Push_Buttons_Position - cannot find MPD for the pcore 'xps_gpio_v1_00_a' in any of the repositories - D:BGSDemonstrationsEDKEDK_DemonstrationsCamera_Frame_Buffer_Demosystem.mhs line 220
ERROR:EDK:4110 - IPNAME: xps_gpio, INSTANCE: DIP_Switches_8Bit - cannot find MPD for the pcore 'xps_gpio_v1_00_a' in any of the repositories - D:BGSDemonstrationsEDKEDK_DemonstrationsCamera_Frame_Buffer_Demosystem.mhs line 233
ERROR:EDK:4110 - IPNAME: clock_generator, INSTANCE: clock_generator_0 - cannot find MPD for the pcore 'clock_generator_v1_00_a' in any of the repositories - D:BGSDemonstrationsEDKEDK_DemonstrationsCamera_Frame_Buffer_Demosystem.mhs line 262
ERROR:EDK:4110 - IPNAME: mpmc, INSTANCE: mpmc_0 - cannot find MPD for the pcore 'mpmc_v4_03_a' in any of the repositories - D:BGSDemonstrationsEDKEDK_DemonstrationsCamera_Frame_Buffer_Demosystem.mhs line 389
ERROR:EDK:4111 - IPNAME: xps_gpio, INSTANCE: LEDs_8Bit - cannot find MPD for the pcore - D:BGSDemonstrationsEDKEDK_DemonstrationsCamera_Frame_Buffer_Demosystem.mhs line 207
ERROR:EDK:4111 - IPNAME: xps_gpio, INSTANCE: Push_Buttons_Position - cannot find MPD for the pcore - D:BGSDemonstrationsEDKEDK_DemonstrationsCamera_Frame_Buffer_Demosystem.mhs line 220
ERROR:EDK:4111 - IPNAME: xps_gpio, INSTANCE: DIP_Switches_8Bit - cannot find MPD for the pcore - D:BGSDemonstrationsEDKEDK_DemonstrationsCamera_Frame_Buffer_Demosystem.mhs line 233
ERROR:EDK:4111 - IPNAME: clock_generator, INSTANCE: clock_generator_0 - cannot find MPD for the pcore - D:BGSDemonstrationsEDKEDK_DemonstrationsCamera_Frame_Buffer_Demosystem.mhs line 262
ERROR:EDK:4111 - IPNAME: mpmc, INSTANCE: mpmc_0 - cannot find MPD for the pcore - D:BGSDemonstrationsEDKEDK_DemonstrationsCamera_Frame_Buffer_Demosystem.mhs line 389
and when I try to open (system.xmp) from the revup it can't open.
how could I open it and implement to spartan for testing.
Please, I need your help.
更多回帖
