ST意法半导体
直播中
林沧禄
8年用户 219经验值
私信 关注
[问答]
请问转换器/驱动程序是否可以进行此转换?
大家好,
目前,我们正在开发基于安全微控制器的产品,用于安全关键应用。
我们希望将Flexray通信转换为光纤单模通信以实现更长距离
转换器/驱动程序是否可以进行此转换?
在我的硬件设计中需要注意哪些必要的事项?
请提供宝贵的反馈意见。
谢谢。
问候,
S.Saravanakumar
以上来自于谷歌翻译
以下为原文
Hello All,
Currently, We are developing a product based up on Safe Microcontroller for safety critical application.
We want to convert the Flexray communication to Optical Fiber single mode communication for longer distance
Is this conversion possible with out Transceivers/Drivers?
What are the necessary things to take care during my hardware design?
Kindly give your valuable feedback.
Thank you.
Regards,
S.Saravanakumar
回帖(3)
刘鑫
2019-6-25 09:23:19
你好 ,
对于Flexray IP微控制器,
你可以使用SPC56EL
http://www.st.com/content/ccc/resource/sales_and_marketing/promotional_material/brochure/group0/ab/e8/ff/0b/65/1d/41/8e/SPC56%2032-bit%20power%20architecture% 20microcontrollers /文件/ brspc56.pdf / JCR:内容/翻译/ en.brspc56.pdf
 对于光纤,您需要一个外部设备。
也许这个,
http://www.st.com/en/interfaces-and-transceivers/serc816.html
 最好的祝福
 二万
以上来自于谷歌翻译
以下为原文
Hello ,
For the Flexray IP microcontroller,
you can use SPC56EL
http://www.st.com/content/ccc/resource/sales_and_marketing/promotional_material/brochure/group0/ab/e8/ff/0b/65/1d/41/8e/SPC56%2032-bit%20power%20architecture%20microcontrollers/files/brspc56.pdf/jcr:content/translations/en.brspc56.pdf
For the optical fiber, you need an external device.
Maybe this one ,
   Best regards
             Erwan
举报
林沧禄
2019-6-25 09:37:39
你好,Erwan,
我已经选择了具有Flexray通信功能的微控制器。
我的问题是,直接将柔性传输通信转换为光纤通信。
按照建议,这个接口控制器可以吗?
/external-link.jspa?url=http%3A%2F%2Fwww.st.com%2Fen%2Finterfaces-and-transceivers%2Fserc816.html
 问候,
S.Saravanakumar
 注意:原始帖子包含大量线程对话,只能迁移到第9级
以上来自于谷歌翻译
以下为原文
Hello Erwan,
Already, I have selected the microcontroller, which has Flexray communication.
My question about, Directly convert the flexray communication to optical fiber communication.
As recommended, is it possible with this Interface controller ??
Regards,
S.Saravanakumar
Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level
举报
刘鑫
2019-6-25 09:47:19
你好
S.Saravanakumar,
我不是光纤通信的专家。
不要犹豫,在OLS工具中发布支持请求
 最好的祝福
 二万
以上来自于谷歌翻译
以下为原文
Hello
S.Saravanakumar ,
i am not expert of Optical Fiber communication.
do not hesitate to post a support request in OLS Tools
  Best regards
               Erwan
举报
更多回帖
