Microchip
直播中
张英
8年用户 209经验值
私信 关注
[问答]
动态DNS代码错误
我最近刚开始使用HARMony和MPLLABX,因为我用MPLAB 8编译和使用TCPIP堆栈v5x的项目已经工作了两年,所以Goggle停止接受SSL连接。我试过添加Wolf SSL,但是无法工作,所以我决定尝试MPLAB X和Harmony。我花了几天试图让他们工作,我决定把SD卡和USB的旧MLA代码移植到我的和谐项目中。在移植它上花了几个小时之后,令人惊讶,令人惊讶——MLA代码没有任何问题地工作。最后要做的是让DDNS工作。再一次,我花了几个小时来弄清楚它为什么不工作——IP地址已经改变,我一直有一个状态DDNS_STATUS_UNCHANGED,不需要更新(在ddns.c中)以下是来自ddns.c的代码的一部分。从情况SM_CHECKIP_FIND_ADDRESS:,如果找到IP地址,代码直接进入情况SM_CHECKIP_DISCONNECT:,而不增加smDDNS。SMDDN增加。代码中的注释是-需要执行更新-即,我们应该到达情况SM_IP_UPDATE_HOME:。但是当smDDNS增加时,它将从SM_CHECKIP_FIND_ADDRESS更改为SM_CHECKIP_DISCONNECT,而不是SM_IP_UPDATE_HOME。这意味着在下一次运行任务时,我们以caseSM_CHECKIP_DISCONNECT结束,lastKnownIP等于ipParsed,我们返回SM_DONE——不需要更新!!!!我的问题的解决方案(除非我漏掉了什么东西)是在SM_CHECKIP_FIND_ADDRESS,smDDNS++的情况下添加。我希望这会帮助具有相同问题的人——除非我错了,并且代码应该正常工作?
以上来自于百度翻译
      以下为原文
    , I have started recently with Harmony and MPLAB X because my project that worked for a couple of years compiled with MPLAB 8 and using TCPIP stack v5xx stopped working - Goggle stopped accepting SSL connection. I have tried adding Wolf SSL but I couldn't get it to work so I decided to try MPLAB X and Harmony.
An example of an app provided with Harmony, using Wolf SSL worked so there was a hope that I can get my project converted (re-done).
After a lot of struggle, and giving up on SD Card and USB Host drivers from Harmony - I spent a couple of days trying to get them working I have decided to port old MLA code for SD Card and USB to my Harmony project. And after a couple of hours spent on porting it, surprise, surprise - MLA code works without any problems.
The last thing to do was to get DDNS working. And again, I have spent a couple of hours to figure out why it doesn't work - IP address has changed and I always had a status DDNS_STATUS_UNCHANGED, no update required (in ddns.c)
Below is part of the code from ddns.c
            smDDNS++;
        case SM_CHECKIP_FIND_ADDRESS:
            // Check if remote node is still connected. If not, force to the disconnect state,
            // but don't break because data may still be waiting.
            if(!TCPIP_TCP_IsConnected(MySocket) || SYS_TMR_TickCountGet() - DDnsTimer > 6*SYS_TMR_TickCounterFrequencyGet())
                smDDNS = SM_CHECKIP_DISCONNECT;
            // Search out the "" delimiter in the response
            wPos = TCPIP_TCP_ArrayFind(MySocket, (const uint8_t*)"", 7, 0, 0, false);
            // If not yet found, break
            if(wPos == 0xffff)
                break;
            // Read and terminate that string as the IP address (preventing buffer overflows)
            if(wPos > 15u)
                wPos = 15;
            TCPIP_TCP_ArrayGet(MySocket, vBuffer, wPos);
            vBuffer[wPos] = '';
            // Parse the IP address that was read, invalidating on failure
            if(!TCPIP_Helper_StringToIPAddress((char*)vBuffer, &ipParsed))
                vBuffer[0] = '';
            // Continue on to close the socket
        case SM_CHECKIP_DISCONNECT:
            // Close the socket
            TCPIP_TCP_Close(MySocket);
            MySocket = INVALID_SOCKET;
            // Determine if an update is necessary
            if(vBuffer[0] == '')
            {// CheckIP Failed
                lastStatus = DDNS_STATUS_CHECKIP_ERROR;
                smDDNS = SM_SOFT_ERROR;
                break;
            if( (ipParsed.Val ==lastKnownIP.Val) && (!bForceUpdate))
                // IP address has not changed and no update is forced
                lastStatus = DDNS_STATUS_UNCHANGED;
                smDDNS = SM_DONE;
                break;
            // Need to perform an update
            lastKnownIP = ipParsed;
            bForceUpdate = false;
            smDDNS++;
            break;
        case SM_IP_UPDATE_HOME:
            netH = TCPIP_STACK_NetDefaultGet();
            // resolve the remote update server
Looking in the code, I saw that there is no chance to get to the  case SM_IP_UPDATE_HOME, and have ddns updated.
From the case SM_CHECKIP_FIND_ADDRESS:, if the IP address is found, the code goes straight into case SM_CHECKIP_DISCONNECT:, without increasing smDDNS.
In  case SM_CHECKIP_DISCONNECT:, if the ipParsed in not equal to lastKnownIP, the lastKnownIP is assigned new value and smDDNS is increased. The comment in the code is - Need to perform an update - i.e. we should get to case SM_IP_UPDATE_HOME:.
But when smDDNS is increased it is changed from SM_CHECKIP_FIND_ADDRESS to SM_CHECKIP_DISCONNECT and not to SM_IP_UPDATE_HOME. This means that on the next run of the task we end up in case SM_CHECKIP_DISCONNECT, lastKnownIP is equal to ipParsed and we go back to SM_DONE - no update required!!!.
My solution to my problem (unless I missed something) was to add in case SM_CHECKIP_FIND_ADDRESS, smDDNS++.
I hope that this will help someone who has the same problem - unless I am wrong and the code should work as it is?
回帖(7)
云达贞
2019-6-25 06:43:13
谢谢你发现这个问题,我们将调查并在下一个版本中包含修复。
以上来自于百度翻译
      以下为原文
    Thank you for finding this issue.
We'll investigate and include the fix in the next release.
举报
蔡柱刚
2019-6-25 07:00:15
RUNAD,虽然这是看,最好是检查从服务器解析响应(我不使用IP)。我发现,大多数时候,我得到LASSTSTATE作为“更新错误”,而响应是好的或NOCHG。下面是我从没有IP获得的响应之一:HTTP/1.1 200 OKCype类型:文本/平原;字符集= UTF 8-连接:CutelCeCH控件:私有的,必须RealValuePrimaMa:没有CaseExcel:-1日期:星期三,2016年10月26日03:54:29 GMTGOOD 124.16924.3
以上来自于百度翻译
      以下为原文
    rainad, while this is looked at, it would be good to check parsing of the response from the server (I am using no-ip). I have found out that most of the time I get lastStatus  as "Update Error" while the response is good or nochg. See below for one of the responses I got from no-ip:
HTTP/1.1 200 OK
Content-Type: text/plain; charset=UTF-8
Connection: close
Cache-Control: private, must-revalidate
pragma: no-cache
expires: -1
Date: Wed, 26 Oct 2016 03:54:29 GMT
good 124.169.248.3
举报
云达贞
2019-6-25 07:20:33
DDNS FIX已经被应用,它将是下一个版本的一部分。感谢找到这个。这个模块已经被移植了,从MLA,并没有被重写为和谐。同样的错误存在于MLA代码中。
以上来自于百度翻译
      以下为原文
    The DDNS fix has been applied and it will be part of the next release.
Thanks for finding this.
This module has been ported as is from MLA and has not been re-written for Harmony.
The same bug is present in the MLA code.
举报
蔡柱刚
2019-6-25 07:27:13
编辑岗位“拒绝访问”
以上来自于百度翻译
      以下为原文
    "Access denied" when editing post
举报
更多回帖
