嗨,我正试图配置发送模块的DSPIC33 EV32 GM00 2微控制器。我已经尝试将它们配置为发射机和接收机。我无法得到输出。我写的代码如下。在这两种情况下,时钟频率fCy=22.1184MHz和嘀嗒周期
tiCKK=3US。1。接收器配置无效InitSENT(void){RPINR44bits.SEINR44bits.SENT11000000000000000000000000000000000000000000000000000000000000000000SENT1CON1比特;SENT1CON1CON1CON1比特.NIBCNBCNT=1;SENT1CON1CON1比特.SENT1CON1CON1比特.NIBCNT=0b110;SENT1CON1CON1比特.NIBCNT 1比特.NIBCNT=0b110;SENT1CON1CON1CON1比特1比特.NIBCNT1NBCNT=0b110;SENT1CON1CON1CON1CON1比特.NIBCNT;SENT1CON1D8bits.SENT1MD=0;IFS11bI.SENT1IF=0;IPC45bit.SENT1IP=0b11;IEC11bit.SENT1IE=1;Delayus(20);SENT1CON1bit.SNTEN=1;Delayus(20);.;}2。发送Modevoid InitSENT(void){RPOR1bits.RP36R=0b111001;TRISB比特.TRISB4=0;TRISB比特.TRISB4=0;SENT1CON11CON1比特.RCVEN=0;SENT1CON1CON1CON1比特.SENT1CON1CON1比特.卷=0;SENT1CON1CON1比特.RCVENT1CON1比特.RCVE=0;SENT1CON1CON1比特.RCVENT1CON1比特.SNTSIDL=0;SENT1CON1CON1比特.SNSNTSIDL=0;TXM=0;TXM=0;0;0;0;0;0;0;0;0;0;0;0;0 CON2=0x0041;SENT1CON3=0x0258;//PMD8BITS,Stord1MD=0;IFS11BITSUNIF=0;IPC45 BITS.SUN1IP= 0B11;IEC11BITSUNIIE=1;Stord1DATL= 0x4FFF;Stord1DaTe= 0x0FF0;Delayus(20);Sun1CON1BITS.SNTEN=1;DelayUS(20);返回;}请帮助我,如果有什么事情要改变的话。
以上来自于百度翻译
以下为原文
Hi,
I am trying to configure the SENT module of the dsPIC33EV32GM002 microcontroller. I have tried to configure them as both transmitter and receiver . I am unable to get the output . The codes I have written are below. In both cases Clock frequency FCY = 22.1184MHz and Tick period TTICK = 3us.
1. Receiver configuration
void InitSENT(void)
RPINR44bits.SENT1R = 0b0010000;
SENT1CON1bits.RCVEN = 1;
SENT1CON1bits.NIBCNT = 0b110;
SENT1CON1bits.CRCEN = 0;
SENT1CON1bits.PPP = 1;
SENT1CON1bits.PS = 0;
SENT1CON1bits.SNTSIDL = 0;
SENT1CON2 = 0x0FDD;
SENT1CON3 = 0x0A93;
//PMD8bits.SENT1MD = 0;
IFS11bits.SENT1IF = 0;
IPC45bits.SENT1IP = 0b11;
IEC11bits.SENT1IE = 1;
Delayus(20);
SENT1CON1bits.SNTEN = 1;
Delayus(20);
return;
2. Transmit Mode
void InitSENT(void)
RPOR1bits.RP36R = 0b111001;
TRISBbits.TRISB4 = 0;
SENT1CON1bits.RCVEN = 0;
SENT1CON1bits.TXM = 0;
SENT1CON1bits.CRCEN = 1;
//SENT1CON1bits.PS = 0;
//SENT1CON1bits.SNTSIDL = 0;
SENT1CON2 = 0x0041;
SENT1CON3 = 0x0258;
SENT1DATL = 0x4FFF;
SENT1DATH = 0x0FF0;
Delayus(20);
Delayus(20);
return;
Please help me if is there any thing to change.
