是德科技
直播中
王云
8年用户 206经验值
私信 关注
[问答]
请问如何才能使34980A停止缩放?
我正在为工厂设置编写测试程序。
我的程序的用户将测试电路板的各种电压和电阻。
我的程序当前向用户显示:A。测试点所在的位置(图片),B。可接受的限制(高,低)和C. 34980A的当前读数。
然而,在某些测试点上,34980A似乎可以缩放值,在低值和高值之间跳转。
如何使34980A停止缩放?
如果将其设置为手动模式将有助于我知道。谢谢!
以上来自于谷歌翻译
     以下为原文
  I am writing a test program for a factory setting.  The user of my program will be testing circuit boards for various voltages and resistances.  My program currently shows the user: A. Where the test point is located (picture), B. The limits (high,low) of what is acceptable and C. The current reading of the 34980A.  On some test points however the 34980A seems to scale the values, jumping between a low value and a high value.  How can I make the 34980A stop scaling?  If setting it to manual mode would help let me know.
Thanks!
回帖(1)
李晨灵
2019-6-13 10:45:27
您好tbueno,您的阅读价值是多少?您设置的限制是什么?
如果你正在使用自动量程并且读数位于范围的边缘,那么它可能会像那样跳跃。
如果您知道您的范围,设置手动范围可能会有所帮助。
如果您仍然遇到此问题,请提供您的配置和预期读数的更多详细信息,然后我会尽力帮助。最好的问候,Tran
以上来自于谷歌翻译
     以下为原文
  Hello tbueno,
What are the value of your readings and what are the limits that you set?  If you're on autorange and the reading is at the edge of the range, it might jump like that.  If you know your range, setting a manual range might help.  If you still experience the issue, please provide more detail of your configuration and expected readings then I'll try my best to help.
Best regards,
Tran
举报
更多回帖
