谢谢Tanio的回复,
但现在我更喜欢使用其他功率级,而不是起动器套件的IGBT。并且会有下一个问题。我的新电源开关所需的PWM信号反转为入门套件的信号。我不知道这些端口的特殊功能寄存器需要哪些更改。我发现我必须改变MPOL寄存器的设置,但我不确定。它们指的是MPHST寄存器和OP [5:0]位,所以我有点不确定。
简单的方法是使用单独的逆变器电路,但我的电路板上没有空间。
我也不知道如何更改这些寄存器。复位MPOL寄存器值为0011 1111,但当我尝试从复位MCU读取它们时,值为1111 1111。
是否真的需要逐位设置值。我对港口选择了解不多。
当他们谈论使用Mosfet而不是IGBT使用的DTE位时,st7用户手册中的补充pwm是什么意思。
我知道这是一个巨大的文字,但我希望任何人都可以帮助我。
最好的祝福。
你真诚的贝恩
以上来自于谷歌翻译
以下为原文
Thank you Tanio for your reply,
but now i prefer to use an other power stage, instead of the IGBT's of the starter Kit. And there will be the next problem. The PWM signals i need for my new Power switches are inverted to the signals from the starter kit. And i don't know which changes are necessary for the special function register for these ports. I found that i have to change the settings of the MPOL register but i'm not sure. they refer to MPHST register and to the OP[5:0] bits, so i'm a bit unsure.
The simple way is to use seperate inverter circuits, but there is no space on my board.
I also don't knew how to change these register. The reset MPOL register value is 0011 1111 but when i tried to read them from the reseted MCU the value is 1111 1111.
Is it realy necessary to set the value bit by bit. I don't know much about port option.
And what does the complementary pwm mean in the st7 user's manual when they talk about the DTE bit whith Mosfet instead of IGBT's used.
I know it is a huge text but i hope anybody could help me.
Best regards.
yours sincerely Benn
谢谢Tanio的回复,
最好的祝福。
你真诚的贝恩
以上来自于谷歌翻译
以下为原文
Best regards.
举报
