我正在寻找这样的功能/设置,它允许输出幅度(信号电平)的共同调节,它将以与电位器/衰减器类似的方式工作。特别是,如果正弦波形1Vpp具有1V的DC偏移,它在输出1.5V最大和0.5时给出
V min。通过将输出电平降低50%,我期望0.5Vpp的正弦和0.5V DC偏移。到目前为止,我没有在任何仪器中找到它。
在诸如33522A这样的现代仪器中是否有任何问题需要实施?
以上来自于谷歌翻译
以下为原文
I am looking for such func
tion/setting which allows common regulation of output amplitude (signal level) which will work in similar way as potentiometer/attenuator.
Especially, if sinusoidal waveform 1Vpp has an DC offset 1V it gives at output 1.5V max and 0.5V min.
By reduction of output level by 50% I expect 0.5Vpp of sinus and 0,5V DC offset.
Up to now I do not find it in any instrument. Is there any problems to implement in in such modern instruments like 33522A?
