STM32/STM8技术论坛
直播中
李华
8年用户 1439经验值
私信 关注
[问答]
STM32与AD73360通讯数据都叠加在MISO线上
STM32工作在从模式,时钟由AD73360提供,只要使能AD73360,便能提供一个不间断的时钟给STM32。STM32在给AD73360发送控制字时,数据都叠加在MISO线上,且周期性持续。目前无法设置。我用的是STM32F303VC。求大神指导。
回帖(18)
李华
2019-5-27 11:58:33
这是我对SPI的GPIO初始化部分
  /** SPI3 GPIO Configuration
  PC10   ------> SPI3_SCK
  PC11   ------> SPI3_MISO
  PC12   ------> SPI3_MOSI
  /*Enable or disable the AHB peripheral clock */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE);
  /*Configure GPIO pin : PC */
  GPIO_InitStruct.GPIO_Pin = GPIO_Pin_10;   //SCK
  GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStruct.GPIO_OType = GPIO_OType_OD;
  GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOC, &GPIO_InitStruct);
        GPIO_InitStruct.GPIO_Pin = GPIO_Pin_11;   //MISO
        GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStruct.GPIO_Pin = GPIO_Pin_12;    //MOSI
  /*Configure GPIO pin alternate function */
  GPIO_PinAFConfig(GPIOC, GPIO_PinSource10, GPIO_AF_6);
  GPIO_PinAFConfig(GPIOC, GPIO_PinSource11, GPIO_AF_6);
  GPIO_PinAFConfig(GPIOC, GPIO_PinSource12, GPIO_AF_6);
举报
李华
2019-5-27 12:09:27
这是我对SPI的初始化代码
SPI_InitTypeDef SPI3_Param;
        GPIO_SetBits(AD_SE_GPIO_PORT, AD_SE_PIN);  //disable AD73360.
        delay_ms(50);
  SPI_I2S_DeInit(SPI3);
        SPI_Cmd(SPI3, DISABLE);     /*½ûÄÜSPI3*/
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI3, ENABLE);
        SPI3_Param.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI3_Param.SPI_Mode = SPI_Mode_Slave;
  SPI3_Param.SPI_DataSize = SPI_DataSize_16b;
  SPI3_Param.SPI_CPOL = SPI_CPOL_Low;    //CPOL = 0
  SPI3_Param.SPI_CPHA = SPI_CPHA_2Edge;  //CPHA = 1
  SPI3_Param.SPI_NSS = SPI_NSS_Soft;
  SPI3_Param.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;
  SPI3_Param.SPI_FirstBit = SPI_FirstBit_MSB;
  SPI3_Param.SPI_CRCPolynomial = 7;
        SPI_Init(SPI3,&SPI3_Param);
        SPI_NSSInternalSoftwareConfig(SPI3, SPI_NSSInternalSoft_Reset);//ÉèÖÃÄÚ²¿NSSΪµÍµçƽ
        SPI_Cmd(SPI3, ENABLE);     /*ʹÄÜSPI3*/
举报
况冶
2019-5-27 12:16:55
没看明白。STM32 的 SPI 工作在从模式是没法主动发送数据的。
举报
况冶
2019-5-27 12:29:28
受到警告
提示: 作者被禁止或删除 内容自动屏蔽
举报
张桂兰
2019-5-27 12:36:41
这个AD多少M的频率?
举报
李华
2019-5-27 12:46:24
从模式可以主动发送数据吧。
举报
李华
2019-5-27 13:00:19
引用: jasonzhang_001 发表于 2019-5-27 15:20
另外你也没提出问题嘛
我目前无法与AD73360通讯。我发送的控制字,都叠加在MISO这条数据线上,示波器看到是周期性的方波。最后将AD73360切换回数据模式后,CPU接收到的数据不是我想要的,而是我最后发送的控制字0x8001。 我不知道是哪边出现问题了
举报
李华
2019-5-27 13:05:24
引用: Shype 发表于 2019-5-27 15:28
这个AD多少M的频率?
16.384M,输出的时钟SCK是2.048M
举报
李华
2019-5-27 13:23:04
另外你也没提出问题嘛
我的意思是,数据发送不是应该一次性的吗,发送完了后MISO上就不应该有波形啊,怎么会出现周期性的方波呢,然后后面还跟前面的叠加起来了。由于数据的叠加,让我无法确定我发送的数据是否正确,只能通过AD73360的表现来判断。目前判断结果就是,AD73360没有被正确设置。
举报
李刚
2019-5-27 13:29:37
从模式没法主动发数据,只有能过中断请求来主动发数据
举报
李华
2019-5-27 13:36:04
我是在中断的时候给AD73360发送数据的。你看我的代码。
void EXTI0_IRQHandler(void)
                if(RESET != EXTI_GetFlagStatus(EXTI_Line0))
                                if(exti0_cnt == 0)
                                {SPI_SendData( 0x8000 );}  //CRA,Program Mode
                                else if(exti0_cnt == 1)
                                {SPI_SendData( 0x8104 );}  //CRB,Decimation Rate£¬8KHz
                                else if(exti0_cnt == 2)
                                {SPI_SendData( 0x8261 );}  //CRC
                                else if(exti0_cnt == 3)
                                {SPI_SendData( 0x8388 );}  //CRD,open ADC1,ADC2
                                else if(exti0_cnt == 4)
                                {SPI_SendData( 0x8408 );}  //CRE,open ADC3,close ADC4
                                else if(exti0_cnt == 5)
                                {SPI_SendData( 0x8500 );}  //CRF,close ADC5,ADC6
                                else if(exti0_cnt == 6)
                                {SPI_SendData( 0x8600 );}  //CRG
                                else if(exti0_cnt == 7)
                                {SPI_SendData( 0x8700 );}  //CRH
                                else if(exti0_cnt == 8)
                                {SPI_SendData( 0x8001 );}  //CRA,Data Mode
                                else if(exti0_cnt == 9)
                                {SPI_SendData( 0x7fff);}   /*¹Ø±Õ¿ØÖÆ×Ö·¢ËÍ*/
                                else if(exti0_cnt >= 10)
                                                while(SPI_ReceptionFIFOStatus_Empty != SPI_GetReceptionFIFOStatus(SPI3))
        ADDataBuffer[SampleNum] = SPI_I2S_ReceiveData16(SPI3);  //½ÓÊÕÊý¾Ý
        SampleNum++;
                                if(SampleNum >= 320)
                                                SampleNum = 0;
                                if(exti0_cnt > 250)
                                        exti0_cnt = 10;
                                exti0_cnt++;
举报
石璞璞
2019-5-27 13:50:17
SPI从机是不能主动发数据的 ,因为时钟是主机提供的。而你说AD73360持续在提供时钟,这个时候你的SPI从机是可以发数据的
举报
李华
2019-5-27 14:05:03
恩。是的。但是我发送的数据却不是一次性的那种。在我发第一个控制字时还正常,发第二个时,数据在MISO上周期性连续。第三个叠加在第二个上,依次类推。但是发送完最后一个后,MISO线上就固定为一个周期性方波了。 好奇怪啊
举报
况冶
2019-5-27 14:15:33
引用: 就好国dd 发表于 2019-5-27 15:37
从模式可以主动发送数据吧。
不可以。。。
举报
李华
2019-5-27 14:28:05
AD73360持续在提供时钟,这个时候SPI从机是可以发数据的
举报
况冶
2019-5-27 14:37:47
那不叫发数据,只是从机将数据放在发送寄存器里面,等待时钟过来后主机读取。
举报
李兆水
2019-5-27 14:50:58
楼主说的MISO上有叠加信号又是什么意思呢?
是杂波吗?还是楼主没有完全描述完问题现象??
举报
池鹄展
2019-5-27 15:10:16
楼主你有些乱了,你测试过不用外部AD73360提供时钟吗?用STM32自己的时钟,然后看下波形,然后确定问题所在
举报
更多回帖
