ST意法半导体
直播中
王雪
7年用户 208经验值
私信 关注
[问答]
测试应用程序出错?
我正在使用测试应用程序'STM test Application for discovery',如果我从未使用它,当我想编译它时,我有3个错误:
FMPLL-IN的值(0)超出范围:[4000000,64000000] configuration.xml / SPC560Bxx_RLA STM测试应用程序发现FMPLL-IN问题
FMPLL-VCO的值(0)超出范围:[256000000,512000000] configuration.xml / SPC560Bxx_RLA发现FMPLL-VCO的STM测试应用程序问题
XOSC的值(0)超出范围:[4000000,16000000] configuration.xml / SPC560Bxx_RLA发现XOSC的STM测试应用程序问题有人可以帮帮我吗?
有人知道那些变量在哪里,哪些是正确的值?
非常感谢。
以上来自于谷歌翻译
以下为原文
I'm using the test application 'STM test Application for discovery'  and also if i never used it, when i want to compile it i have this 3 errors:
FMPLL-IN has a value (0) out of range: [4000000,64000000] configuration.xml /SPC560Bxx_RLA STM Test Application for Discovery FMPLL-IN Problem
FMPLL-VCO has a value (0) out of range: [256000000,512000000] configuration.xml /SPC560Bxx_RLA STM Test Application for Discovery FMPLL-VCO Problem
XOSC has a value (0) out of range: [4000000,16000000] configuration.xml /SPC560Bxx_RLA STM Test Application for Discovery XOSC ProblemCan someone help me??
Does someone knows where are those variables and which are the correct values??
Many thanks.
回帖(1)
刘鑫
2019-5-24 10:45:35
丹尼尔你好,
您已经完成了默认设置。
您可以在测试应用程序中使用SPC560Bxx Clocktree来检查您的时钟点。
无论如何,请参考RM的允许值。 (Cf时钟章节)
 最好的祝福
 二万
以上来自于谷歌翻译
以下为原文
Hello Daniele ,
You have chnaged the default settings.
You can use SPC560Bxx Clocktree in the test application to check your clockpoint.
anyway, please refer to the RM for the permitted value. (Cf Clock Chapter)
  Best regards
                 Erwan
举报
更多回帖
