是德科技
直播中
韩凤英
7年用户 230经验值
私信 关注
[问答]
有关于1mW/50MHz Ref源输出稳定性的信息
有没有人有关于1mW / 50MHz Ref源输出稳定性的信息。
我对输出功率变化感兴趣而不是特殊限制。我曾尝试用432A / 478A-H76热保护器测量1mW输出源,但我发现Ref输出功率从0.995到1.003mW不等(mount一直在
没有重新连接的相同位置)。
这是正常的表现吗?
从432A表开始,我已经将Vcomp和Vref电压从HP 3458A DVM中取出,并根据E4418B服务指南计算出这些电压值的功率输出。我应该在测量过程中考虑一些问题吗?
以上来自于谷歌翻译
     以下为原文
  Does anyone has information about 1mW/50MHz Ref source output stability. I'm interested about output power variation not the spesification limits.
I have tried to measure 1mW output source with 432A/478A-H76 thermisor mount, but i have found that Ref putput power variying from 0.995 to 1.003mW (mount
is all the time at the same position without re-connecting). Is it normal behaving? From 432A meter i have taken Vcomp and Vref voltages
to HP 3458A DVM and calculated power output from those voltage values as E4418B service guide says.
Should i take account some issues during that measurement process?
回帖(1)
李建平
2019-5-24 15:24:19
E4418B中1 mW参考的规格包括短期和长期稳定性。
在23摄氏度+/- 3摄氏度规格范围内,您的测量值远低于+/- 0.5%。
因此它通过了校准测试。由于E4418B的1 mW参考信号,热敏电阻安装座及其电缆以及您正在使用的432A / 3458A的温度和时间不稳定性,您将在一段时间内获得信号电平的一些变化。
所有这些变量都应包含在进行校准时使用的不确定度分析中。但你没事。
你在规范范围内。
以上来自于谷歌翻译
     以下为原文
  The specifications for the 1 mW reference in the E4418B include short term and long term stability.  Your measured value is well within the +/-0.5% over the 23 degree C +/- 3 degrees C specification.  So it passes it calibration test.
You will get some variation in signal levels over time due to temperature and time instabilities in both the E4418B's 1 mW reference signal, the thermistor mount and its cable, and the 432A/3458A you are using.  All of these variables should be included in the uncertainty analysis you are using when making this calibration.
But you are fine.  You are within spec.
举报
更多回帖
