您好我想象,通过VB宏或可能是CSV导入,我应该可以在史密斯圆图上为VSWR构建一个恒定的Z圆=一些值(例如2,2,4,3等对应
典型的回报损失)。
我不知道如何编程VB宏,我不知道这种方法是否相关。
请有人建议(a)这是可能的吗?(b)我该如何去做?
它不必作为限制线 - 只是一个视觉参考,所以我可以看到我的轨迹有多少被包裹起来(在例如VSWR = 2圈内)。
一个固定的圆(VSWR = 2)就可以了,一个可调整的圆(用户从三个固定值中选择)会更好。
感谢您对此事的任何帮助
以上来自于谷歌翻译
以下为原文
Hello
I'm imagining that, via a VB macro or possibly a CSV import, it should be possible for me to construct a constant Z circle on the Smith chart for VSWR = some value (e.g. 2, 2.4, 3 etc. to correspond with typical return losses).
I don't know how to program VB macros and I don't know if that approach would be per
tinent. please couold someone suggest (a) is this possible and (b) how might I go about it?
It doesn't have to function as a limit line - just a visual reference so I can see how much of my locus is wrapped up (inside the e.g. VSWR=2 circle). A fixed circle (VSWR=2) would be fine, an adjustable one (user selects from three fixed values for example) would be even nicer.
Thanks for any help on this matter
