嗨,我正在使用N8754A进行ATS编程。
我可以假设使用命令编程时N8754A的下降/上升时间如下所述吗?
下降时间(满载)150ms(下降时间+指令响应时间)上升时间(满载)130ms(上升时间+指令响应时间)下降时间(空载)800ms上升时间(空载)?
电压下降时间和上升时间小于150ms和130ms是否会在16V至0V之间变化,电流在下降时从200A变为0A,在0到16V之间电流从0到200A上升到上升时间?
我可以知道空载时的上升时间是多少?
(未附在数据表中。)谢谢。
以上来自于谷歌翻译
以下为原文
Hi,
I'm using N8754A for ATS programming.
Can I assume that the fall/rise
time of N8754A when using command programming as stated below?
Fall time (full load) 150ms (down-prog time+ command response time)
Rise time (full load) 130ms (up-prog time+ command response time)
Fall time (no load) 800ms
Rise time (no load) ?
Will the fall time and rise time less than 150ms and 130ms at voltage varies 16V to 0V with current varies from 200A to 0A for fall time and 0 to 16V with current varies from 0 to 200A for rise time?
Can I know what is the rise time at no load? (It is not stated in the datasheet attached.)
Thanks.
附件
