DSP论坛
直播中
崔琛
8年用户 55经验值
擅长:嵌入式技术
私信 关注
sci
求一个SCI的FIFO模式下的接收与发送函数
回帖(1)
尚文清
2019-5-7 18:28:45
void sciaFifoInit(void) {
        EALLOW;        // Map SCI interrupts to ISR functions
        PieVectTable.SCIRXINTA = &sciaRxFifoIsr;
        PieVectTable.SCITXINTA = &sciaTxFifoIsr;
        EDIS;
        SciaRegs.SCICCR.all =0x0007;                // 1 Stop bit,  no loopback
        // no parity, 8 char bits,
        // async mode, idle-line protocol
        SciaRegs.SCICTL1.all =0x0003;                // Enable TX, RX, internal SCICLK,
        // disable RX ERR, SLEEP, TXWAKE
        SciaRegs.SCICTL2.bit.TXINTENA =1;        // Enable Tx interrupt
        SciaRegs.SCICTL2.bit.RXBKINTENA =1;        // Enable RX interrupt
        SciaRegs.SCIHBAUD = 0x0000;                  // SCI BRR = LSPCLK/(SCI BAUDx8) - 1
        SciaRegs.SCILBAUD = 0x00C2;                        // BRR = (15MHz/(Baud x 8)) - 1. 9600 Baud = 194d = C2h.
        SciaRegs.SCIFFTX.all = 0xC022;                // Hold SCI in reset, enable FIFO, hold FIFO in reset, clear FIFO status, clear int, enable int,  set int level to 0
        SciaRegs.SCIFFRX.all = 0x0022;                // Clear overflow flag, hold FIFO in reset, clear FIFO status, clear int, enable int, set int level to 3
        SciaRegs.SCIFFCT.all = 0x00;                // Disable auto-baud feature and set Tx delay to 0
        SciaRegs.SCICTL1.all = 0x0023;     // Relinquish SCI from Reset
        SciaRegs.SCIFFTX.bit.TXFIFOXRESET = 1;
        SciaRegs.SCIFFRX.bit.RXFIFORESET = 1;
        PieCtrlRegs.PIECTRL.bit.ENPIE = 1;        // Enable the PIE block
        PieCtrlRegs.PIEIER9.bit.INTx1=1;        // PIE Group 9, INT1
        PieCtrlRegs.PIEIER9.bit.INTx2=1;        // PIE Group 9, INT2
        IER |= M_INT9;
interrupt void sciaRxFifoIsr (void) {
        // SCI FIFO interrupt (SCIRXINTA) indicating the SCI FIFO has recieved some data
        Uint16 rxBuffer[CNTRL_BUF_LEN];
    Uint16 i;
        for (i=0; i                 rxBuffer[i] = SciaRegs.SCIRXBUF.all;                // Read into buffer byte-by-byte
        sciaTx(0);        // Tx response to confirm reciept
        SciaRegs.SCIFFRX.bit.RXFFOVRCLR=1;                // Clear Overflow flag
        SciaRegs.SCIFFRX.bit.RXFFINTCLR=1;                // Clear Interrupt flag
        PieCtrlRegs.PIEACK.bit.ACK9 = 1;                                // Acknowledge CPU interrupt
interrupt void sciaTxFifoIsr(void) {
举报
更多回帖
