Microchip
直播中
吴少杰
8年用户 189经验值
私信 关注
[问答]
MPLAB XC8 v1.41 PIC18F24K40中的Const表存在问题
在我的一个项目中有一些表,当我使用这个Tab蕾时,在WrreReGiStEnter()中看到错误的数据;函数。当我添加一些虚拟数据(从来没有使用过)时,它是正确的。在模拟器中,当我跟踪时,错误的数字
以上来自于百度翻译
      以下为原文
    In one of the my project there is some table
const u8 const RegistersCfg[] = {10, 20, 50};
and when I use this table
WriteRegister(i, RegistersCfg);
I see wrong data inside the WriteRegister(); function.
It is works correct when I add some dummy data (that never used) before
const char const Data[] = "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA"
"BBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBB"
"CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC"
"DDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDD";
The difference in listing are
Correct code
6                               psect    mediumconst,global,reloc=2,class=MEDIUMCONST,delta=1,noexec
  2050                           ;sx1212driver.c: 109: if (i < 0x14) WriteRegister(i, RegistersCfg);
  2051  000766  0E14                   movlw    20
  2052  000768  600A                   cpfslt    InitRFChip@i,c
  2053  00076A  D00D                   goto    l2128
  2054  00076C  0EDF                   movlw    low _RegistersCfg
  2055  00076E  240A                   addwf    InitRFChip@i,w,c
  2056  000770  6EF6                   movwf    tblptrl,c
  2057  000772  6AF7                   clrf    tblptrh,c
  2058  000774  0E3F                   movlw    high _RegistersCfg
  2059  000776  22F7                   addwfc    tblptrh,f,c
  2060  000778                         if    0    ;There are less than 3 active tblptr bytes
  2061  000778                         endif
  2062  000778  0008                   tblrd        *
  2063  00077A  CFF5 F004              movff    tablat,WriteRegister@value
  2064  00077E  500A                   movf    InitRFChip@i,w,c
  2065  000780  EC65  F004             call    _WriteRegister
  2066  000784  D00C                   goto    l2130
  2067  000786                     l2128:
Wrong code
6                               psect    smallconst,global,reloc=2,class=SMALLCONST,delta=1,noexec
2097                           ;sx1212driver.c: 109: if (i < 0x14) WriteRegister(i, RegistersCfg);
  2098  000BBC  0E14                   movlw    20
  2099  000BBE  600A                   cpfslt    InitRFChip@i,c
  2100  000BC0  D00D                   goto    l2126
  2101  000BC2  500A                   movf    InitRFChip@i,w,c
  2102  000BC4  0F01                   addlw    low _RegistersCfg
  2103  000BC6  6E08                   movwf    ??_InitRFChip& (0+255),c
  2104  000BC8  C008  FFF6             movff    ??_InitRFChip,tblptrl
  2111  000BCC  0008                   tblrd        *
  2112  000BCE  FFFF                   dw    65535    ; errata NOP
  2113  000BD0  CFF5 F004              movff    tablat,WriteRegister@value
  2114  000BD4  500A                   movf    InitRFChip@i,w,c
  2115  000BD6  ECB7  F006             call    _WriteRegister
  2116  000BDA  D00D                   goto    l2128
  2117  000BDC                     l2126:
  2118  000BDC  FFFF                   dw    65535    ; assembler added errata NOP
All errata, that I try to apply are not helps
I see even in the simulator wrong numbers when I trace the
回帖(5)
王焕树
2019-5-6 14:32:17
这将是一个很好的想法来展示你正在使用的PIC设备。它是K40吗?
以上来自于百度翻译
      以下为原文
    It would have been a really good idea to reveal what PIC device you are working with.
Is it a K40?
举报
冯超
2019-5-6 14:50:46
对不起,是PIC18F24K40
以上来自于百度翻译
      以下为原文
    Sorry, Yes it is PIC18F24K40
举报
王焕树
2019-5-6 14:59:57
在过去的两个月里,关于XC8和K40芯片的问题有多个主题。请参阅:http://www. McCys/Foals/M96972.ASPXHTTP://www. McCHIP.COM/FUMMS/M957 860.ASPXhttp://www. McCHIP.COM/FUMMS/M96517ASPXand更多。最后一行,获得XC8的最新版本,并添加规范。已更改的勘误表切换到它。
以上来自于百度翻译
      以下为原文
    There have been multiple topics about problems with XC8 and K40 chips in the last two months.
See:
http://www.microchip.com/forums/m967972.aspx
http://www.microchip.com/forums/m957860.aspx
http://www.microchip.com/forums/m965517.aspx
and more.
Bottom line, get the latest version of XC8, and add the specified errata switch to it.
举报
何兰兰
2019-5-6 15:07:16
它看起来不像K40问题(NVMCON1=0x80;//硅勘误表3.1)。它看起来像是常见的编译器问题。如果我在代码中添加了我的代码(在模拟器中,但是在硬件上是一样的,正如我所看到的),我看到它是正确的。
以上来自于百度翻译
      以下为原文
    It isn't looks like K40 problem (with NVMCON1 = 0x80; //Silicon Errata 3.1). Its looks like common compiler problem. I see that it works correct if I add follow line to the my code (in the simulator, but in hardware it is the same, as I can see).
   TBLPTR = &RegistersCfg[0];
   if (i < REG_RSSIVALUE) WriteRegister(i, RegistersCfg);
PS So now listing is follow
  2099                           ;sx1212driver.c: 107: {
  2100                           ;sx1212driver.c: 108: NVMCON1 = 0x80;
  2101  000BAA  0E80                   movlw    128
  2102  000BAC  6E81                   movwf    3969,c    ;volatile
  2103
  2104                           ;sx1212driver.c: 109: TBLPTR = &RegistersCfg[0];
  2105  000BAE  0E01                   movlw    low _RegistersCfg
  2106  000BB0  6EF6                   movwf    tblptrl,c    ;volatile
  2107  000BB2  0E04                   movlw    high _RegistersCfg
  2108  000BB4  6EF7                   movwf    tblptrh,c    ;volatile
  2109  000BB6  0E00                   movlw    low (_RegistersCfg shr (0+16))
  2110  000BB8  6EF8                   movwf    tblptru,c    ;volatile
  2111
  2112                           ;sx1212driver.c: 110: if (i < 0x14) WriteRegister(i, RegistersCfg);
  2113  000BBA  0E14                   movlw    20
  2114  000BBC  600B                   cpfslt    InitRFChip@i,c
  2115  000BBE  D00C                   goto    l2190
  2116  000BC0  500B                   movf    InitRFChip@i,w,c
  2117  000BC2  0F01                   addlw    low _RegistersCfg
  2118  000BC4  6E09                   movwf    ??_InitRFChip& (0+255),c
  2119  000BC6  C009  FFF6             movff    ??_InitRFChip,tblptrl
  2120  000BCA                         if    0    ;There is only one active tblptr byte
  2121  000BCA                         endif
  2122  000BCA                         if    0    ;tblptru may be non-zero
  2123  000BCA                         endif
  2124  000BCA                         if    0    ;tblptru may be non-zero
  2125  000BCA                         endif
  2126  000BCA  0008                   tblrd        *
  2127  000BCC  CFF5 F005              movff    tablat,WriteRegister@value
  2128  000BD0  500B                   movf    InitRFChip@i,w,c
  2129  000BD2  EC5A  F006             call    _WriteRegister
  2130  000BD6  D00B                   goto    l2192
  2131  000BD8                     l2190:
举报
更多回帖
