您还可以添加ENA的型号和固件版本。
过去,touchstone文件仅针对单端参数进行了定义。
因此节省意味着保存单端然后转换。
较新的固件允许将Sdd保存为试金石(理解当然,它违反了touchstone文件的规则,即单端数据)。
如果固件不够新,无法支持更灵活的试金石保存,您可能需要以不同的格式保存,例如CITI文件。
以上来自于谷歌翻译
以下为原文
You might also add the model number of the ENA and the firmware rev.
In the past, touchstone files were only defined for single-ended parameters. So saving meant saving the single-ended and then converting. Newer firmware allowed saving Sdd as a touchstone (under the understanding, of course, that it violated the rule of touchstone files being single-ended data).
You might need to save as a different format such as CITI file for you situation, if the firmware isn't new enough to support more flexible touchstone saves.
您还可以添加ENA的型号和固件版本。
因此节省意味着保存单端然后转换。
以上来自于谷歌翻译
以下为原文
举报
