是德科技
直播中
李艳茹
8年用户 163经验值
私信 关注
[问答]
是否可以使用DSO81304B示波器进行集成范围的RMS相位抖动测量?
嗨,是否可以使用DSO81304B示波器进行集成范围的RMS相位抖动测量?
根据我的理解,我必须获得相位噪声图(dbc / Hz),在我的规范指定的频率范围内进行积分,然后再回到时域。
是否有可以执行此操作的软件包,或仅使用频谱分析仪进行此类测量?
问候,迈克尔
以上来自于谷歌翻译
     以下为原文
  Hi,
Is it possible to do an RMS Phase Jitter measurement with an integration range using a DSO81304B scope? From my understanding, I'd have to obtain a phase noise plot (dbc/Hz), integrate within the frequency range that my spec specifies and subsequently go back into the time domain. Is there a software package that would do this or is this type of measurement only possible with a spectrum analyzer?
Regards,
Michael
回帖(2)
周菊
2019-4-16 09:37:06
是的,这是可能的,但它不是范围上标准(或可选)工具包的一部分。
我知道有人编写了实现此功能的MATLAB脚本。
花了很长时间才能做到正确,并产生与频谱分析仪方法相关的结果。
以上来自于谷歌翻译
     以下为原文
  Yes, it's possible, but it's not part of the standard (or optional) toolkits on the scope. I know someone who wrote a MATLAB script that implemented this functionality. It took a long time to get it right, and producing results that correlated to the spectrum analyzer approach.
Al
举报
王茜
2019-4-16 09:53:04
迈克尔,如果你想要的只是带限相位抖动,你不需要经历转换为相位噪声。
您只需在带通模式下打开TIE滤波器即可完成此操作。
然后,TIE测量的RMS值与该范围内积分的相位抖动相同。
标记。
以上来自于谷歌翻译
     以下为原文
  Michael,
You don't need to go through the conversion to phase noise if all you want is the band-limited phase jitter. You can do this by simply turning on the TIE filter in bandpass mode. The RMS value of the TIE measurement is then the same as the phase jitter integrated over that range.
Mark.
举报
更多回帖
