赛灵思
直播中
孙宇
8年用户 145经验值
私信 关注
[问答]
是否可以仅将捕获的数据从ILA保存到文件中?
大家好
我试图只将从ILA捕获的数据保存到特定文件中。
我从xilinx网站上找到的是
write_hw_ila_data命令
但是,当我打开捕获的数据时(.ila)
似乎它不仅包括数据,还包括所有东西。
例如,
如果ILA正在捕获端口A上的流数据(10'h0~10'hf),
如果ILA正在捕获端口B上的流数据(10'haa~10'hff),
是否可以保存数据A&
portA&中的dataB
端口B?
我可以提取吗?
还是有其他选择只选择数据?
谢谢
以上来自于谷歌翻译
以下为原文
Hi all expert
I am trying to save only data which is captured from ILA into a specific file.
What i found from xilinx web site is
write_hw_ila_data command
However, when I opened the captured data (.ila)
it seems like it include every thing not only data.
For example,
if ILA is capturing streaming data ( 10'h0 ~ 10'hf) on the portA,
also if ILA is capturing streaming data (10'haa ~ 10'hff) on the portB,
is it possible to save dataA & dataB in portA & portB?
can I extract? or is there any other option to select only data?
Thank you
回帖(1)
励黎
2019-4-16 08:17:39
感谢您对@ vsrunga的评论
我附上了我捕获的ila数据(我删除了一些我不想保存的信号)
对于4096个深度样本,只有一个数据全为零
当我打开文件时,它看起来像上面
我只想要特定数据端口的数据0000到0000
你有没有可能吗?
谢谢
以上来自于谷歌翻译
以下为原文
Thank you for comment @vsrunga
I attached my captured ila data (i removed some signal that I don't want to save)
There is only one data which is all zero for 4096 depth samples
when I open the file, it looks like above
I want data 0000 to 0000 only for the specific data port
Do you thihk it is possible?
Thank you
举报
更多回帖
