我不再有文档,但我认为这是正常的。
插件的正电源仅为+ 20V,因此1V / GHz输出无法达到22V。后扫描器允许您选择1V / GHz或0.5V / GHz,但这种变化有
没有发生86290B插件。
这真的会引起问题吗?
它仅用于少数应用......
以上来自于谷歌翻译
以下为原文
I don't have the documentation any longer, but I think this is normal. The positive supply to the plug-in is only +20Volts, so the 1V/GHz output can't quite manage to make it to 22V.
Later sweepers allowed you to select either 1V/GHz or 0.5V/GHz, but that change had not happened for the 86290B plug-in. Is this really causing a problem? It was only used in a few applications...
我不再有文档,但我认为这是正常的。
没有发生86290B插件。
这真的会引起问题吗?
它仅用于少数应用......
以上来自于谷歌翻译
以下为原文
举报
