赛灵思
直播中
张婷婷
7年用户 179经验值
私信 关注
[问答]
怎么下载完整版本的6.1i
我的任务是重建一台烧毁的硬盘并用它取出硬盘。
我现在已经建立了系统并且正在运行,但我需要重新安装计算机上的软件才能使用他们为该主板编写的程序。
我甚至不确定该主板是否仍然有效,但不管怎样,我仍然需要该软件。
有人可以给我一个链接,我可以下载完整版的6.1i,以便我可以测试板和PC吗?
谢谢
干草堆
以上来自于谷歌翻译
以下为原文
I have been tasked to rebuild a PC that burnt up and took the hard drive out with it.
I have the system built now and is working but I need to reinstall the software that was on the computer in order for them to use their program that was wrote for that board. I am not even sure if the board still works, but either way, I still need the software.
Can someone provide me a link to where I can download a full version of 6.1i so I can test the board and PC?
Thanks
Rick
回帖(2)
刘溪
2019-4-8 14:55:29
你好
检查以下链接
http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/design-tools/archive.html
问候,萨蒂什-----------------------------------------------
--- --------------------------------------------请注意
- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子。感谢.--
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Hi
Check below link
Regards,
Satish
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful.
--------------------------------------------------​-------------------------------------------View solution in original post
举报
陈存楼
2019-4-8 15:28:18
谢谢Satish!
以上来自于谷歌翻译
以下为原文
Thanks Satish!
举报
更多回帖
