Microchip
直播中
张飞
8年用户 163经验值
私信 关注
[问答]
请问什么是LCD定时?什么是时间方面的策略?
嗨,我有一个简单的分段显示(8个SEG和4个公共),并且已经理解了语法和初始化可以用代码驱动分段显示。我从来没有用分段显示来实际构建一个设备UI……是否有人在你需要UPDDA的时间上有什么指针?为人眼展示屏幕?什么是时间方面的策略?我已经准备好如何展示显示角色的功能,但是很难掌握时间。任何帮助,都要感谢有人使用分段显示之前建造的东西。谢谢!
以上来自于百度翻译
      以下为原文
    Hi,
I've got a simple segmented display (8 segs, and 4 commons) and have figured out the syntax and initilization can drive the segmented display in code.
I've never actually built a device UI using a segmented display....
Does anyone have any pointers on the timing for how quickly you need to be updating the screen for the human eye?  What is the strategy in terms of timing?
I'm already noodling how to built out the functions to display the characters, but having a hard time grasping the timing.
Any help, is much appreciated from someone who has built something using a segmented display before.
Thanks!
回帖(5)
陈晨
2019-4-4 15:09:21
30Hz是最小的,但可以检测到。更好的是,接近50或60可以与灯交互,所以你需要70Hz或以上才能不具有这种效果。
以上来自于百度翻译
      以下为原文
    30Hz is minimum, but detectable.. more is better.
close to 50 or 60 may interact with lights, so you would need to be 70Hz or above to not have that effect
举报
王焕树
2019-4-4 15:16:47
大多数小型液晶显示器的响应时间非常慢,所以通常可以慢得多的刷新。
以上来自于百度翻译
      以下为原文
    Most small LCDs have very slow response times though, so you can usually get away with much slower refresh.
举报
陈晨
2019-4-4 15:32:36
液晶显示器?用PIC液晶驱动外围设备?100赫兹应该是好的。检查玻璃的数据表,看看什么是最佳的。靠近DC会使玻璃质量下降。
以上来自于百度翻译
      以下为原文
    LCD? with a PIC LCD Driver peripheral? 100Hz should be fine.  Check the Data sheet for the Glass to see what is optimal for it.  To close to DC can degrade the Glasss.
举报
张翔
2019-4-4 15:48:32
哈哈,数据表?这些都像0.05美元的显示与自定义字符。我很幸运我得到了一个PIN…
以上来自于百度翻译
      以下为原文
    HAHA, datasheet?  These are like $0.05USD displays with custom characters.  I'm lucky I got a pin-out....!
举报
更多回帖
