我正在使用VEE pro来控制SMU U2722A的电压。
我使用I / O直接与SMU
通信。
当我直接键入I / O中的代码时。
a)写文本“volt 15,(@ 1)” - > SMU可以在通道1输出值因为我们需要使用GUI以便于使用,所以我决定将输入终端直接输入到I / O所以我可以改变
使用“text constant / real 64”的电压。
所以我输入的命令如下:b)写文本“volt”+ volt_1 +“,(@ 1)” - > volt_1是变量。
SMU仅在volt_1变量时输出1.098V偶数值。我检查了循环,每次循环变量值“volt_1”都被更新。
我已经尝试过其他***)写文本“volt volt_1,(@ 1)” - >给出相同的结果1.098V。希望有人可以帮助我。
谢谢
以上来自于谷歌翻译
以下为原文
I am using VEE pro to control SMU U2722A voltage. I use I/O direct to communicate with SMU. When i key-in the codes in I/O direct.
a)write text "volt 15, (@1)" --> The SMU can output the value at channel 1
Since we need to use GUI for easier usage, so i decided to put input terminal to I/O direct so i can vary the voltage using "text constant/ real 64". so the command i put is as below
b)write text "volt"+ volt_1+",(@1)" -->volt_1 is the variable. the SMU only outputs 1.098V even values change at volt_1 variable.
I have check the loop, and every
time it loops the variable value "volt_1" is been updated. i have tried other method code
c) write text "volt volt_1,(@1)"--> gives out the same results 1.098V.
Hope anyone can help me on this. Thank You
