综合技术
直播中
李红梅
8年用户 138经验值
私信 关注
[问答]
请问移植DMP,上电后出现如下情况是怎么回事?
  移植DMP,上电后出现如下情况:
compass not found.
mpu initialization complete......
mpu_set_sensor complete ......
mpu_configure_fifo complete ......
mpu_set_sample_rate complete ......
dmp_load_motion_driver_firmware come across error ......
dmp_set_orientation complete ......
dmp_enable_feature complete ......
dmp_set_fifo_rate complete ......
setting bias succesfully ......
mpu_set_dmp_state come across error ......
求大神指导
回帖(4)
王文霞
2019-4-3 12:21:35
帮顶....
举报
李莉
2019-4-3 12:30:36
#include "stm32_iic.h"
#define  SCL_H         GPIOB->BSRR = GPIO_Pin_6
#define  SCL_L         GPIOB->BRR  = GPIO_Pin_6
#define  SDA_H         GPIOB->BSRR = GPIO_Pin_7
#define  SDA_L         GPIOB->BRR  = GPIO_Pin_7
#define  SCL_read      GPIOB->IDR  & GPIO_Pin_6
#define  SDA_read      GPIOB->IDR  & GPIO_Pin_7
//IICר?????±????
static void I2C_delay(void)
    volatile int i = 40;
    while (i)
    i--;
 void delay5ms(void)
   int i=5000;
   while(i)
     i--;
//IIC??????????
void i2cInit(void)
    GPIO_InitTypeDef GPIO_InitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
static bool I2C_Start(void)
    SDA_H;
    SCL_H;
    I2C_delay();
    if (!SDA_read)
        return false;
    SDA_L;
    I2C_delay();
    if (SDA_read)
        return false;
    SDA_L;
    I2C_delay();
    return true;
static void I2C_Stop(void)
    SCL_L;
    I2C_delay();
    SDA_L;
    I2C_delay();
    SCL_H;
    I2C_delay();
    SDA_H;
    I2C_delay();
static void I2C_Ack(void)
    SCL_L;
    I2C_delay();
    SDA_L;
    I2C_delay();
    SCL_H;
    I2C_delay();
    SCL_L;
    I2C_delay();
static void I2C_NoAck(void)
    SCL_L;
    I2C_delay();
    SDA_H;
    I2C_delay();
    SCL_H;
    I2C_delay();
    SCL_L;
    I2C_delay();
static bool I2C_WaitAck(void)
 u8  ucErrTime=0;
    SCL_L;
    I2C_delay();
    SDA_H;
    I2C_delay();
    SCL_H;
    I2C_delay();
    if (SDA_read)
    {ucErrTime++;
if(ucErrTime>250)
I2C_Stop();
 return false;
       // SCL_L;
        return false;
    SCL_L;
    return true;
static void I2C_SendByte(uint8_t byte)
    uint8_t i = 8;
    while (i--)
        SCL_L;
        I2C_delay();
        if (byte & 0x80)
            SDA_H;
        else
            SDA_L;
        byte <<= 1;
        I2C_delay();
        SCL_H;
        I2C_delay();
    SCL_L;
static uint8_t I2C_ReceiveByte(void)
    uint8_t i = 8;
    uint8_t byte = 0;
    SDA_H;
    while (i--)
        byte <<= 1;
        SCL_L;
        I2C_delay();
        SCL_H;
        I2C_delay();
        if (SDA_read)
            byte |= 0x01;
    SCL_L;
    return byte;
bool i2cWriteBuffer(uint8_t addr, uint8_t reg, uint8_t len, uint8_t * data)
    int i;
    if (!I2C_Start())
        return false;
    I2C_SendByte(addr << 1 | I2C_Direction_Transmitter);
    if (!I2C_WaitAck())
        I2C_Stop();
        return false;
    I2C_SendByte(reg);
    I2C_WaitAck();
    for (i = 0; i < len; i++)
        I2C_SendByte(data);
        if (!I2C_WaitAck())
            I2C_Stop();
            return false;
data++;
    I2C_Stop();
delay5ms();
    return true;
int8_t i2cwrite(uint8_t addr, uint8_t reg, uint8_t len, uint8_t * data)
if(i2cWriteBuffer(addr,reg,len,data))
return TRUE;
else
// return FALSE;
return FALSE;
int8_t i2cread(uint8_t addr, uint8_t reg, uint8_t len, uint8_t *buf)
if(i2cRead(addr,reg,len,buf))
return TRUE;
else
return FALSE;
//return FALSE;
bool i2cWrite(uint8_t addr, uint8_t reg, uint8_t data)
    if (!I2C_Start())
        return false;
    if (!I2C_WaitAck())
        I2C_Stop();
        return false;
    I2C_SendByte(reg);
    I2C_WaitAck();
    I2C_SendByte(data);
    I2C_WaitAck();
    I2C_Stop();
delay5ms();
    return true;
bool i2cRead(uint8_t addr, uint8_t reg, uint8_t len, uint8_t *buf)
    if (!I2C_Start())
        return false;
    if (!I2C_WaitAck())
        I2C_Stop();
        return false;
    I2C_SendByte(reg);
    I2C_WaitAck();
    I2C_Start();
    I2C_SendByte(addr << 1 | I2C_Direction_Receiver);
    I2C_WaitAck();
    while (len)
        *buf = I2C_ReceiveByte();
        if (len == 1)
            I2C_NoAck();
        else
            I2C_Ack();
        buf++;
        len--;
    I2C_Stop();
    return true;
uint16_t i2cGetErrorCounter(void)
    // TODO maybe fix this, but since this is test code, doesn't matter.
    return 0;
各位帮忙看看这个IIC哪出问题了?
举报
王文娥
2019-4-3 12:42:32
你好,你试过用SPI读取MPU9250的磁力计数据吗?我再这块遇到问题了,不知道怎么解决?
举报
王颖群
2019-4-3 13:01:12
没有
举报
更多回帖
