MHC V1.10文件系统演示应用NVMYSDCDATA FA
tiAL多磁盘使用一个文件名为NvvMyDISKSimult.c,其中包含用于放置PIC32程序存储器的FAT12图像文件。文件中的注释表明“这个文件可以手工生成,作为sys fs配置实用程序的一部分。”(sys fs)在主和声页上被神秘地提及,但没有解释。这个实用程序是什么?有人能指点我吗?它似乎是Linux内存映像生成器,但我不确定。我试着用MPDS2生成器工具来做这个“MDD”图像选项,但是没有生成这样的东西,只有DynRcrd.bin和FielCrd.Bin。两个都不包含任何东西,只有几个字节。谢谢,PaulEdit:哦,MPDS2生成器中的MDD选项是刚才的前和声文件系统。不是我要找的。
以上来自于百度翻译
以下为原文
The MHC v1.10 file system demo application nvm_sdcard_fat_multidisk uses a file named nvm_disk_images.c that contains the FAT12 image file for placing in PIC32 program memory. The comments in the file indicate that "This file may be generated manually as a part of SYS FS Configuration utility." (SYS FS) is mentioned cryptically on the main H
ARMony page, but with no explanation.
What is this utility? Can someone point me to it? It appears to be a linux memory image generator but I'm not sure. I tried to do this with the MPFS2 generator utility with the "MDD" image option, but nothing like this was generated, just DynRcrd.bin and FileRcrd.bin. Neither of which contained anything but a few bytes.
Thanks,
Paul
Edit: Oh, the MDD option in the MPFS2 generator is the just old pre-Harmony file system. Not what I'm looking for.
