Microchip
直播中
杨会
8年用户 228经验值
私信 关注
[问答]
怎么在图形picKIT3调试器中绘制数据
受到警告
提示: 作者被禁止或删除 内容自动屏蔽
回帖(3)
陈晨
2019-4-1 14:17:17
把你的数据铲出一个串口或USB,并在PC上捕获它。
以上来自于百度翻译
      以下为原文
    Shovel your data out a serial port or USB, and capture it on a PC.
举报
贾熹
2019-4-1 14:27:39
没有更多的选择了吗?我不知道如何使用UART。
以上来自于百度翻译
      以下为原文
    And there aren´t more options? I don´t know how to use the UART
举报
朱佳婧
2019-4-1 14:34:14
如果你不能使用插件,你可能需要开发一些软件工具(也许在Windows上),它可以执行基于GUI输入/输出的操作。另一方面,正如NKurzman所建议的,你需要某种类型的PIC32和G.Soththiguy通信(即UART)。如果我不交流它,我还能告诉你什么吗?因为你有低端程序员(PICTIT3),你甚至不会和RealICE相比,它的价格更高,更有能力。显然,你需要工作,因为插件不是选项,所以你必须做一些广泛的工作来开发。要么就是这样,要么你小心翼翼地去尝试并尝试插件,它本质上和NKurzman和我所描述的一样,只是不同的通信介质和集成的GUI。
以上来自于百度翻译
      以下为原文
    If you cannot use the plug-in, you will probably have to develop some software utility (perhaps on Windows) that can execute operations based on GUI inputs/outputs.
Another thing, as NKurzman suggested, you need some sort of PIC32 -> _SOMETHING_ communication (i.e. UART).  How else can I tell you something if I don't communicate it...
Since you have low-end programmer (PICkit3) you aren't even going to compare to RealICE which is 5x more expensive and more capable.  Obviously you are asking for work-around since plug-in is not option, so you have to do some extensive work to develop.  Either this, or you pony up and get RealICE and try plug-in which is essentially doing same thing NKurzman and I are describing, just different communication medium and integrated GUI.
举报
更多回帖
