Viewnets 选在左边net list 选GND net,加到右边view list。在右边选GND,下面view unroute details 选none, 在左边颜色中选一个颜色。
这样地线的飞线就hide起来了,并且是同一种颜色。当然这里要小心信号地和power地要分开先。
这样的设置布局起来就方便多了。早知道就好,ft。
2.改全部元件的字体属性。和protel一样,这个是可以一次全部改成相同的属性的。
单击鼠标右键,选select components, 再单击右键,选 select all (CTRL+A)。再单击右键,选query/modify (CTRL+Q), part outline width 输入想要的宽度,下面选label, 选Ref. Des. Press the big button under it. 弹出新窗口, input the value you want at size and width. Press OK. Then the size, width , even the part outline width are same. 有点麻烦。呵呵。
单击老鼠右键,check “select net”, select the net you want to add via, usually, GND net, the GND is high light. Then right click mouse again, select “ add via”, then you can add vias which are connected to GND net. Freely and put them wherever you want. Remember, if the GND net is hide and set to a special color, no connecTIon for these vias, but they are same color as other pads and trace in GND net.
