自问自答吧:问题解决了
在USB2.0协议文档中,关于Set Address和Set configuration是这么说的:
关于地址设置:设为0,则设备处于Default state;设成非0地址,则设备处于Address state
>>Default state: If the address specified is non-zero, then the device shall enter the Address state;
otherwise, the device remains in the Default state (this is not an error condition).
>>Address state: If the address specified is zero, then the device shall enter the Default state;
otherwise, the device remains in the Address state but uses the newly-specified
address.
>>Configured state: Device behavior when this request is received while the device is in the Configured
state is not specified.
关于Set Configuration:对处于Default state下的设备Set Configuration是错误的。
>>Default state: Device behavior when this request is received while the device is in the Default state
is not specified.
>>Address state: If the specified configuration value is zero, then the device remains in the Address
state. If the specified configuration value matches the configuration value from a
configuration descriptor, then that configuration is selected and the device enters the
Configured state. Otherwise, the device responds with a Request Error.
>>Configured state: If the specified configuration value is zero, then the device enters the Address state.
configuration descriptor, then that configuration is selected and the device remains in
the Configured state. Otherwise, the device responds with a Request Error.
SO,只要设置一个非0的地址就什么都好了!
自问自答吧:问题解决了
address.
is not specified.
举报
