> {quote:title = Dr_joel写道:} {quote}>对噪声系数的两个主要影响是:接收器类型和耦合因子。
>>有三种或四种常见接收器类型,最差到最佳:> 1)基于采样器:非常高的噪声系数 - 8753和8720使用采样器工作在VCO的200至300次谐波> 2)高次谐波混频器(或
低谐波采样器) - 许多毫米波系统使用它;
谐波操作高达10或12或更多> 3)低谐波混频器 - PNA在26.5GHz以上的分析仪中使用三次谐波混频,PNA-L在13 GHz以上使用它,我认为。
> 4)基本混合 - 噪声系数最低。
>>耦合因子范围从50 dB(在微波耦合器的低端,接近10 MHz)到12 dB(在高端)> 8753使用16 dB,ENA类似但具有更接近的高功率版本
到20 dB。
>>将耦合系数添加到分析仪的噪声系数中,您就得到了整体噪声系数。
Fieldfox N9923A使用什么样的接收器?
由于电池耗尽和尺寸,我预计会有相当多的妥协。
以上来自于谷歌翻译
以下为原文
> {quote:title=Dr_joel wrote:}{quote}
> Two principal impacts on noise figure are: receiver type and coupling factor.
> There are three or four common receiver types, for worst to best:
> 1) Sampler based: very high noise figure - 8753 and 8720 use samplers operating on 200th to 300th harmonic of the VCO
> 2) High harmonic mixer (or low harmonic samplers) - many mm-wave systems use this; operation on harmonics up to 10 or 12 or more
> 3) Low harmonic mixer - PNA uses third harmonic mixing in analyzers above 26.5GHz, PNA-L uses it above 13 GHz, I think.
> 4) Fundamental mixing - Lowest noise figure.
> The coupling factor ranges from 50 dB (at the low end of the microwave couplers, near 10 MHz) to 12 dB (at the high end)
> 8753 uses 16 dB, ENA is similar but has a high power version that is closer to 20 dB.
> Add the coupling factor to the noise figure of the analyzer and you have the overall noise figure.
What sort of receiver does the Fieldfox N9923A use? I expect there has to be quite a few compromises on that due to battery drain and size.
> 4)基本混合 - 噪声系数最低。
到20 dB。
以上来自于谷歌翻译
以下为原文
举报
