韦东山Linux嵌入式课程社区
直播中
倪山骋
7年用户 1025经验值
私信 关注
用老师代码反汇编结果与老师的反汇编代码不同
为啥我用老师的代码反汇编结果与老师的反汇编代码不同?
led.c
  • int main()
  •         unsigned int *pGPFCON = (unsigned int *)0x56000050;
  •         unsigned int *pGPFDAT = (unsigned int *)0x56000054;
  •         /* 配置GPF4为输出引脚 */
  •         *pGPFCON = 0x100;
  •         /* 设置GPF4输出0 */
  •         *pGPFDAT = 0;
  •         return 0;
复制代码
start.S
  • .text
  • .global _start
  • _start:
  •         /* 设置内存: sp 栈 */
  •         ldr sp, =4096  /* nand启动 */
  • //        ldr sp, =0x40000000+4096  /* nor启动 */
  •         /* 调用main */
  •         bl main
  • halt:
  •         b halt
复制代码
我的反汇编
  • led.elf:     file format elf32-littleARM
  • Disassembly of section .text:
  • 00000000 <_start>:
  •    0:        e3a0da01         mov        sp, #4096        ; 0x1000
  •    4:        eb000000         bl        c
  • 00000008 :
  •    8:        eafffffe         b        8
  • 0000000c
  •    c:        e52db004         push        {fp}                ; (str fp, [sp, #-4]!)
  •   10:        e28db000         add        fp, sp, #0        ; 0x0
  •   14:        e24dd00c         sub        sp, sp, #12        ; 0xc
  •   18:        e3a03456         mov        r3, #1442840576        ; 0x56000000
  •   1c:        e2833050         add        r3, r3, #80        ; 0x50
  •   20:        e50b300c         str        r3, [fp, #-12]
  •   24:        e3a03456         mov        r3, #1442840576        ; 0x56000000
  •   28:        e2833054         add        r3, r3, #84        ; 0x54
  •   2c:        e50b3008         str        r3, [fp, #-8]
  •   30:        e51b200c         ldr        r2, [fp, #-12]
  •   34:        e3a03c01         mov        r3, #256        ; 0x100
  •   38:        e5823000         str        r3, [r2]
  •   3c:        e51b2008         ldr        r2, [fp, #-8]
  •   40:        e3a03000         mov        r3, #0        ; 0x0
  •   44:        e5823000         str        r3, [r2]
  •   48:        e3a03000         mov        r3, #0        ; 0x0
  •   4c:        e1a00003         mov        r0, r3
  •   50:        e28bd000         add        sp, fp, #0        ; 0x0
  •   54:        e8bd0800         pop        {fp}
  •   58:        e12fff1e         bx        lr
复制代码
老师的反汇编
  • led.elf:     file format elf32-littlearm
  •    4:        eb000000         bl        c
  • 00000008 :
  •    8:        eafffffe         b        8
  • 0000000c
  •    c:        e1a0c00d         mov        ip, sp
  •   10:        e92dd800         stmdb        sp!, {fp, ip, lr, pc}
  •   14:        e24cb004         sub        fp, ip, #4        ; 0x4
  •   18:        e24dd008         sub        sp, sp, #8        ; 0x8
  •   1c:        e3a03456         mov        r3, #1442840576        ; 0x56000000
  •   20:        e2833050         add        r3, r3, #80        ; 0x50
  •   24:        e50b3010         str        r3, [fp, #-16]
  •   28:        e3a03456         mov        r3, #1442840576        ; 0x56000000
  •   2c:        e2833054         add        r3, r3, #84        ; 0x54
  •   30:        e50b3014         str        r3, [fp, #-20]
  •   34:        e51b2010         ldr        r2, [fp, #-16]
  •   38:        e3a03c01         mov        r3, #256        ; 0x100
  •   3c:        e5823000         str        r3, [r2]
  •   40:        e51b2014         ldr        r2, [fp, #-20]
  •   44:        e3a03000         mov        r3, #0        ; 0x0
  •   48:        e5823000         str        r3, [r2]
  •   4c:        e3a03000         mov        r3, #0        ; 0x0
  •   50:        e1a00003         mov        r0, r3
  •   54:        e24bd00c         sub        sp, fp, #12        ; 0xc
  •   58:        e89da800         ldmia        sp, {fp, sp, pc}
复制代码
回帖(2)
刘军
2019-3-25 13:26:46
我的反汇编出来也不一样,看编译器及版本了吧,不过即便不完全一样,代码最终的功能也肯定是一样的
需要自己分析了,或者用老师的代码分析,道理一样的就行
举报
李微波
2019-3-25 13:41:57
编译器版本问题吧
举报
更多回帖
