您的理解是正确的,并且stream-to-fifo模式恰好是用于此目的的正确模式。
FIFO内容将由触发事件之前收集的#30个样本,生成中断事件的样本和触发后的一个样本组成。
请查看应用笔记中的9.3.4章
http://www.st.com/content/ccc/resource/technical/document/application_note/77/ed/e7/e1/28/5a/45/d6/CD00290365.pdf/files/CD00290365.pdf/jcr:内容/翻译/ en.CD00290365.pdf
以上来自于谷歌翻译
以下为原文
You understanding is correct and the stream-to-fifo mode is exactly the right mode for the purpose.
FIFO content will be composed of #30 samples collected before the trigger event, the sample that has generated the interrupt event and one sample after the trigger.
Please check chapter 9.3.4 in the application note
http://www.st.com/content/ccc/resource/technical/document/application_note/77/ed/e7/e1/28/5a/45/d6/CD00290365.pdf/files/CD00290365.pdf/jcr:content/translations/en.CD00290365.pdf
请查看应用笔记中的9.3.4章
以上来自于谷歌翻译
以下为原文
举报
