如果您的信号接地与PSoC接地隔离,那么您可以将AGND带到PSoC的外部引脚,并将信号连接到这个AGND上。如果您的信号接地与PSoC的VSS相同,则可以使用电容器将信号连接到PSoC的输入端,并将PSoC的输入偏置到AGND。看看下面的文章,这两种方法都有更多的细节。使用PSOC1最佳测量负电压,PSoC黑客GANSIH
以上来自于百度翻译
以下为原文
If your signal ground is isolated from PSoC ground, then you can bring out the AGND to an external pin of PSoC and connect the signal with respect to this AGND.
If your signal ground is same as VSS of PSoC, then the signal can be connected to the input of PSoC using a capacitor and biasing the input of PSoC to AGND. Check out the below article that has more details on both these methods.
Measuring Negative Voltage Using PSoC1
Best Regards,
Ganesh
The PSoC Hacker
以上来自于百度翻译
以下为原文
Best Regards,
Ganesh
The PSoC Hacker
举报
