赛灵思
直播中
余英姿
8年用户 216经验值
私信 关注
[问答]
如何根据来自外围设备的信号选择KINTEX 7中的库?
海大家,
我正在使用Kintex7。
Kintex 7使用诸如ADC,时钟,LVDS线,存储器,DAC等外围设备。
我的问题,
这样我的设计就信号的时序进行了优化。
请给出一些一般性的想法,以便我可以在时间点上注意信号。
theertha
以上来自于谷歌翻译
以下为原文
Hai everyone,
   I am using Kintex7. Kintex 7 uses pheripherals like  ADC, clock, LVDS lines, Memory, DAC.
My question,
How to choose the banks in  KINTEX 7 with respect to the  signals from the pheripheral..? so that my design is optimized with respect to timing of the signals.
please give some general idea so that i can take care the signals in point of timings.
theertha
回帖(1)
李森
2019-3-18 10:34:39
应首先针对PCB布局优化接口,然后如果接口大于存储体,则每个接口应放置在同一存储体或相邻存储体内。
------您是否尝试在Google中输入问题?
如果没有,你应该在发布之前。太多结果?
尝试添加网站:www.xilinx.com
以上来自于谷歌翻译
以下为原文
The interfaces should first be optimized for the PCB layout and then each interface should be placed within the same bank or adjacent banks if the interface is larger than a bank.
------Have you tried typing your question into Google?  If not you should before posting.
Too many results?  Try adding site:www.xilinx.com
举报
更多回帖
