赛灵思
直播中
谢微微
8年用户 180经验值
私信 关注
[问答]
Ubuntu上的XPS不运行
嗨,大家好
我正在尝试在Ubunto上运行Xilinx EDK,在阅读了很多主题后,我做了这个脚本:
#!/斌/庆典
cd /opt/Xilinx/12.3/ISE_DS/ISEsource settings32.shcd /opt/Xilinx/12.3/ISE_DS/EDKsource settings32.sh
cd /opt/Xilinx/12.3/ISE_DS/EDK/bin/lin./xps
我的问题是,当我运行此脚本时,没有任何错误,没有错误,但xps没有打开
另一方面,我有其他的scirpt运行ise工作完美。
以上来自于谷歌翻译
以下为原文
Hi everyone
I am trying to run Xilinx EDK on Ubunto, after reading a lot of topics, i did this script:
#!/bin/bash
./xps
my problems is that when i run this script nothing ocurred, no errors, but xps is not opened
in other hand, i have other scirpt to run ise that work perfectly.
回帖(1)
姚庭芳
2019-3-15 07:48:39
嗨,
检查这个帖子:http://forums.xilinx.com/t5/Installation-and-Lensingensing/ISE-12-1-on-Linux-Ubuntu-EDK-does-not-start/td-p/73616
谢谢,
维奈
------------------------------------------您是否尝试在Google中输入问题?
如果没有,你应该在发布之前。
此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。
以上来自于谷歌翻译
以下为原文
Hi,
check this thread: http://forums.xilinx.com/t5/Installation-and-Licensing/ISE-12-1-on-Linux-Ubuntu-EDK-does-not-start/td-p/73616
Thanks,
Vinay
Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.
举报
更多回帖
