是德科技
直播中
徐小婷
7年用户 206经验值
私信 关注
[问答]
M8190A上所需信号周围的无用信号
嗨,M8190A上的安捷伦大师,我只买了2个M8910A(产品版本2)来取代原版1单元。
我试图从M8190A生成多个音调信号。
但是我总是通过freq在我想要的信号周围得到不需要的多个信号产物。
偏移20.8KHz(312,000个样本长度),或2.08KHz,3,120,000个样本长度。
即使我将所有“1”加载到通道1并且将“0”加载到通道2,我仍然遇到同样的问题。
有时它没有出现,信号很干净。
但大部分时间都发生在我的两个单位上。
我的版本1单元没有出现此问题。
我已经想到并检查了ref信号,从内部采样信号(从“采样时钟输出”端口始终有+ / 1 270Hz信号)并重启PC和M8190A(和驱动程序)多次,但是甚至找不到
解决方法!
很沮丧!!
仅供参考,我使用C#生成DAC值并使用IVI驱动程序加载到设备。
但就像我说的,即使加载“1”和“0”也会导致同样的问题。
我几乎得出的结论是硬件有问题。
您的及时帮助真的很感激!!!
射线
以上来自于谷歌翻译
     以下为原文
  Hi, Agilent guru on M8190A,
I just got 2 of M8910As (product version 2) to replace original version 1 unit. I was trying to generate multiple tone signals from M8190As. But I always got unwanted multiple products of signals around my desired signals with freq. offset 20.8KHz (for 312,000 sample length), or 2.08KHz for 3,120,000 sample length.  Even if I loaded all "1" to channel 1 and "0" to channel 2, I still got the same problem. Sometimes it didn't show up and the signals were very clean. But most of time it happened, on both of my units.
I didn't get this problem with my version 1 unit.
I have thought of and checked ref signal, sampling signals from internal (which always has +/1 270Hz signals around from "Sample Clock out" port) and rebooted PC and M8190A (and driver) many times, but couldn't find even a workaround!!  Very frustrated!!
FYI, I am using C# to generate the DAC values and load to the unit with IVI driver.  But like I said, even loading "1" and "0" will cause the same problem. I am almost coming to the conclusion that the hardware has the problem.
Your timely help is truly appreciated!!!
Ray
回帖(2)
徐小婷
2019-3-14 14:43:00
这里附有我的简化程序和结果。
如果有人能提供帮助,真的很感激!
Ray 408-807-7896
M8190A.zip33.8 KB
以上来自于谷歌翻译
     以下为原文
  Here attached is my simplified program and the results.
Really appreciate it if anyone can help!
Ray
408-807-7896
附件
举报
杨云
2019-3-14 14:58:45
引用: muuwfwr 发表于 2019-3-14 14:43
这里附有我的简化程序和结果。
如果有人能提供帮助,真的很感激!
Ray 408-807-7896
您好Ray,为了找出M8190A没有按预期运行的原因,请确保安装了最新的固件版本(http://www.agilent.com/find/M8190)。
要验证硬件是否正常工作,请运行程序“sine.exe”(在C: Program Files(x86) Agilent  M8190  Examples下),并确认从diect DAC输出中获得干净的225 MHz信号
如果你仍然看到相同的扭曲,我怀疑存在硬件问题。
在这种情况下,请联系您当地的Agilent销售代表。
否则,请通过bvs-pdga_support@agilent.com与我们联系,以便对问题进行更深入的分析。
谢谢,托马斯
以上来自于谷歌翻译
     以下为原文
  Hello Ray,
In order to find out what why your M8190A does not behave as expected, please make sure that you have the latest firmware version installed (http://www.agilent.com/find/M8190).
To verify that the hardware works correctly, please run the program "sine.exe" (under C:Program Files (x86)AgilentM8190Examples) and verify that you get a clean 225 MHz signal out of the diect DAC output.
If you still see the same distortions, I suspect that there is a hardware problem. In this case, please contact your local Agilent sales representative. Otherwise, please contact us at bvs-pdga_support@agilent.com for forther analysis of the problem.
Thanks,
Thomas
举报
更多回帖
