Cypress技术论坛
直播中
王红梅
7年用户 183经验值
私信 关注
[问答]
输入到输出互连和输出到输入互连
我试图把一个输出列勾回到芯片的输入端,这样我就可以在不同的行中使用这个信号。我需要通过行来输出互连,以在行上执行块或块之间的异或。这阻止了我使用行的广播特性。我知道无论我选择输入输出互连或反之亦然的图标是一样的:输入输出。我在哪里可以找到关于这个资源的信息?或者有人能解释一下?
以上来自于百度翻译
     以下为原文
  I'm trying to hook an output column back to the input side of the chip so I can use the signal in a different row.  I need to go through the Row to output interconnect to perform an exclusive or between to blocks on the row.  This prevents me from using the broadcast feature of the row. I notice that whether I select input to output interconnect or vise versa the icon remains the same: input to output.  Where do I find information about this resource? Or can someone explain?
回帖(1)
黄欢
2019-3-14 13:21:48
输出和输入输出路径覆盖的技术参考手册修订版D 14.2.1和14.2.2章输入,包含在帮助文件的文件夹。我在PSoC设计器5.1中构建了CY8C2644的简单项目。它起广告作用。如果你想直接和你的电话号码,电子邮件seg@cypress.com和我会很高兴的叫。
Dennis Seguine
以上来自于百度翻译
     以下为原文
  The input to output  and output to input routing is covered in chapters 14.2.1 and 14.2.2 in the Technical Reference Manual revision D, contained in the helpdocumentation folder. I built a simple project in CY8C27443 in PSoC Designer 5.1. It works as advertised. If you want to talk directly, email your phone number to seg@cypress.com and I'll be happy to call.
    ---- Dennis Seguine
举报
更多回帖
