ST意法半导体
直播中
郭淑慧
7年用户 159经验值
私信 关注
[问答]
STEVAL-IDB007V1M根本不发送
我正在尝试使用SPBTLE-1S模块进行评估。我正在使用BlueNRG-1 Navigator v 2.6.0。如果我闪存任何演示应用程序,则无法在手机上发现BLE服务(Nexus 5X,Android 7.1.1。)
例如。 BLE传感器演示 - 复位后DL3短路闪烁,然后BL1略微闪烁,因此芯片正在做某事,但没有射频信号。 (以前的芯片ti CC2540与同一部手机正确通信。)
我错过了什么或芯片坏了吗?
以上来自于谷歌翻译
以下为原文
I'm trying eval board with SPBTLE-1S module. I'm using BlueNRG-1 Navigator v 2.6.0. If I flash any demo application, no BLE service can be discovered on the phone (Nexus 5X, Android 7.1.1.)
E.g. BLE Sensor demo - DL3 shorty blinks after reset, then BL1 slightly flashes, so the chip is doing something, but no RF signal. (Previous chip TI CC2540 has communicated correctly, with the same phone.)
Have I missed something or is the chip broken?
回帖(5)
樊周依
2019-3-12 14:10:02
嗨托马斯,
请注意所有的例子都包括在内
BlueNRG-1 Navigator v 2.6.0已预先配置为
STEVAL-IDB007V1板。在您的情况下,您使用的是STEVAL-IDB007V1,它需要不同的配置。实际上,你的董事会是基于
SPBTLE-1S模块,具有32 MHz晶振。您为BlueNRG-1找到的所有示例通常都配置为16 MHz晶振(EVAL-IDB007V1电路板中使用的晶体)。为了使用STEVAL-IDB007V1M测试示例,您必须重建它们为32 MHz 。请确保在项目设置中定义:
有关更多信息,您还可以关注此主题
https://community.st.com/0D50X00009XkWquSAF
。最好的祝福,
安东尼奥
 注意:原始帖子包含大量线程对话,只能迁移到第9级
以上来自于谷歌翻译
以下为原文
Hi Tomas,
please notice that all the examples included in the
BlueNRG-1 Navigator v 2.6.0 are preconfigured for the
STEVAL-IDB007V1 board. In your case, instead, you're using an STEVAL-IDB007V1, which needs a different configuration. Indeed, your board is based on the
SPBTLE-1S module, which has a 32 MHz crystal. All the examples that you have found for BlueNRG-1 are usually configured for a 16 MHz crystal (the one used in the EVAL-IDB007V1 board).In order to test the examples with STEVAL-IDB007V1M, you have to rebuild them for 32 MHz. Please make sure that in your project settings you define this:
For more information, you can also follow this thread about
.Best regards,
Antonio
Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level
举报
郭淑慧
2019-3-12 14:28:08
嗨Antonio,
我已经找到了那个帖子(不是之前,否则我不应该写帖子),而且,如果我理解正确的话,那么只使用BlueNRG Navigator就不可能在没有重建的情况下使用任何示例吗?
我没有任何支持的IDE(我们正在使用Rowley Crossworks),我想先尝试一些(现成的!)示例,然后再深入研究项目并将其转换为IDE。
你可以把你的BLE_SensorDemo.hex发送给我,编译为32MHz Xtal,就像你为Wolfgang做的那样吗?
我非常接近将卖单作为碎片送回卖方。
最好的祝福,
 托马斯
以上来自于谷歌翻译
以下为原文
Hi Antonio,
I have already found that thread (not before, otherwise I shouldn't have written the post), and, if I understand it correctly, it is impossible to make any example working without rebuild, using BlueNRG Navigator only?
I don't have any supported IDE (we are using Rowley Crossworks) and I would like first to try some (ready made!) example before I dig into the project and convert it to our IDE.
Could you please send me the BLE_SensorDemo.hex, compiled for 32MHz Xtal, as you did for Wolfgang?
I was very near to send the board back to the seller as broken piece.
Best regards,
  Tomas
举报
樊周依
2019-3-12 14:34:29
嗨托马斯,
这是BLE_SensorDemo.hex文件,编译为32MHz Xtal。
如果这对您有用,请告诉我,因为我自己没有任何STEVAL-IDB007V1M进行测试。
最好的祝福,
安东尼奥
以上来自于谷歌翻译
以下为原文
Hi Tomas,
here is the BLE_SensorDemo.hex file, compiled for 32MHz Xtal.
Please let me know if this works for you, as I don't have any STEVAL-IDB007V1M to test it myself.
Best regards,
Antonio
举报
郭淑慧
2019-3-12 14:43:23
嗨Antonio,
大!按预期工作,非常感谢。
遗憾的是原版二进制文件对于这个版本来说是无用的
举报
更多回帖
