Cypress技术论坛
直播中
董达勇
7年用户 216经验值
私信 关注
[问答]
在第二列仍然是噪音
感谢ENOA参数。数据表状态:
ENOA噪声在1千赫(功率=介质,Opamp Bias =高)- 100 - NV/RT赫兹
但是无论如何,我将正弦曲线引入到PGA跟随器(增益=1)中,除此之外,我监视第一列中的输入和输出,并且得到图像1,得到预期的。
输入=输出(端口03)
(Vsin输入=500赫兹1VPP和1V偏移)
当我在第二行做同样的事情时,我得到了一个有噪声的正弦波输出。输出等于输入,但噪声远高于数据表中所规定的规格,所以我仍然认为我的部分被损坏。
图像3显示附加噪声在800 kHz和1MHz附近。
你觉得怎么样?
损坏了我的部分?
顺便说一下,我有一个RC过滤器在我的端口0Y5板出局。
它会产生噪音吗?
以上来自于百度翻译
     以下为原文
  Thanks about the Enoa parameter. The datasheets states:
    ENOA Noise at 1 kHz (Power = Medium, Opamp Bias = High) – 100 – nV/rt-Hz
    But anyway, I introduce  a sinusoid into a PGA follower  (Gain=1) and apart  I monitories the input and output in the First column and I get the image 1, obtaining the expected.
    Input=Output (Port 0_3)
    (Vsin input= 500Hz 1Vpp and 1Voffset)
    When I did the same in the second row I got a noisy sinusoid  output.  The output is equal to the input but the noise is much higher than the specifications told in the datasheet, so I still thinking my part is damaged.
    Image 3 shows the add noise is around 800KHz and 1MHz.
What do you think about it?
    Is damaged my part?
                    By the way, I have a RC filter in my Port 0_5  board outout.
    Could it produce the noise?
回帖(1)
肖晓新
2019-3-6 14:47:55
你好,
你有可能使用CY314板吗?如果是这样的话,是什么修订?
该委员会对P0.5引脚,用于CapSense电容。如果你输出一个模拟信号对P0.5,输出将不会因为在PSoC器件不能模拟输出缓冲器驱动大电容。主板上的电容约10 NF和模拟输出缓冲器可驱动200 pF左右,最大。所以,这就是为什么你看到如此意外的信号P0.5。
我会尝试在输出或焊F221试着从你的板拆卸电容C7。
最好的问候,本
以上来自于百度翻译
     以下为原文
  Hi,
    Are you by any chance using a CY3214 board? If so, what revision is it?
    This board has a capacitor on the P0.5 pin that is used for CapSense. If you output an analog signal on P0.5, your output will not be as expected because the analog output buffers in the PSoC device cannot drive very large capacitances. The capacitor on the board is around 10 nF and the analog output buffer can drive around 200 pF, max. So, this is why you are seeing a signal on P0.5 that is so unexpected.
    I would either try the output on P0.3 or try removing capacitor C7 from your board.
    Best regards,
Ben
举报
更多回帖
