ST意法半导体
直播中
谢芳芳
7年用户 138经验值
私信 关注
[问答]
如何检查BlueNRG-MS版本是否会影响其他任何命令?
当我在BlueNRG-MS重置后运行aci_hal_write_config_data()作为第一个命令时,我得到ERR_CMD_SUCCESS。但是当我首先调用getBlueNRGVersion()时,我从aci_hal_write_config_data()获取ERR_COMMAND_DISALLOWED。是什么原因?如何检查BlueNRG-MS版本是否会影响其他任何命令?
#command #version #aci #bluenrg-ms
以上来自于谷歌翻译
以下为原文
When I run aci_hal_write_config_data() as a first command after BlueNRG-MS reset, I get ERR_CMD_SUCCESS. But when I call getBlueNRGVersion() first, then I get ERR_COMMAND_DISALLOWED from aci_hal_write_config_data(). What is the reason? How checking BlueNRG-MS version can affect any other command?
回帖(3)
樊周依
2019-3-4 06:50:09
亲爱的Niemirowski Grzegorz,
更改配置数据可能会影响芯片的后续行为,因此只有在复位后的第一个命令时才能调用aci_hal_write_config_data()。
如果你需要先调用getBlueNRGVersion(),只需在获得版本后重置芯片,然后你就可以毫无问题地调用aci_hal_write_config_data()。
希望有所帮助。
以上来自于谷歌翻译
以下为原文
Dear Niemirowski Grzegorz,
changing configuration data may affect the subsequent behavior of the chip and so aci_hal_write_config_data() can be called only if it is the first command after reset.
If you need to call getBlueNRGVersion() first, just reset the chip after you got the version, and then you'll be able to call aci_hal_write_config_data() without any issues.
Hope that helps.
举报
樊周依
2019-3-4 07:02:58
检查版本不会影响其他命令,但是,作为完整性检查,BlueNRG / BlueNRG-MS固件不允许在您发出任何其他命令后调用aci_hal_write_config_data()。因此,您既不能调用影响后续行为的命令,也不能调用不影响后续行为的命令(如版本检查)。
以上来自于谷歌翻译
以下为原文
Checking the version does not affect other commands, but, as a sanity check, the BlueNRG/BlueNRG-MS firmware does not allow calling aci_hal_write_config_data() after you have issued any other commands. So you cannot call neither commands that affect subsequent behavior nor commands that don't (like the version check).
举报
谢芳芳
2019-3-4 07:11:01
一切都清楚了。谢谢!
以上来自于谷歌翻译
以下为原文
Everything is now clear. Thanks!
举报
更多回帖
