我同意QHB,此外,为什么需要使用汇编语言?C更容易使用,1或2秒定时器工作得比C好。C组件通常只用于从MPU中挤出更多的性能。你当然不需要这里。但是,如果你真的需要使用这个MPU和汇编,我会帮助你。你看过数据表了吗?你下载并安装了免费的MPLABX软件吗?数据表解释了很多。让我知道你需要什么帮助。
以上来自于百度翻译
以下为原文
I agree with qhb, in addition, why do you need to use assembly language? C is easier to use and a 1 or 2 second timer will work more than fine with C. Assembly is usually only used to squeeze a little more performance out of the MPU. You certainly don't need that here.
However, if you really need to use that MPU and assembly, I'll help.
You're going to have to help yourself, though, too. Have you read the data sheet? Have you downloaded and installed the free MPLABX software? The data sheet explains a lot. Let me know what you need help with.
以上来自于百度翻译
以下为原文
举报
