在你的设计中,64K闪存是如何连接到FX2的????如果你下载DVK,你可以注意到FX2连接到一个SRAM并使用它作为外部存储器,在这种操作中它可以理论上有一个64K大小的固件。KEIL工具链能够生成代码存储固件…我所困惑的是,你是不是真的在使用一个串行接口,并不时地下载代码到内部RAM,试图实现代码银行,或者你使用一个并行接口,并想对它进行编码。
以上来自于百度翻译
以下为原文
How is this 64k flash connected to FX2 in your design???
If you download the DVK, you can notice in the schematic that FX2 is connected to a SRAM and uses it as external memory and in this kind of operation it can theoretically have a firmware of size 64k...
Keil tool chain is capable of generating code banked firmware... what i'm confused is whether you are actually using a serial interface and downloading code to internal RAM from time to time and trying to achieve code banking or are you using a parallel interface and want to code bank it....
以上来自于百度翻译
以下为原文
举报
