版本A.01.09是截至今天的当前版本。
固件下载页面中的这个注释可能有助于解释您在agilent.com网站和仪表本身之间看到的差异:-------------------------
----------------------------------------------适用于N1913A和
N1914A功率计。
版本:A.01.09兼容性:EPM系列N1913A和N1914A功率计日期:2013年9月10日请注意,固件安装到功率计后,固件版本中会增加一个数字。
固件版本中第一个字母后添加的数字将指定功率计中功率传感器通道的数量。
例如,安装在双通道N1914A中的A.01.05固件现在将在功率计的显示屏上显示为A2.01.05;
安装在单通道N1913A中的固件版本将为A1.01.05。
---------------------这是所有安捷伦功率计当前固件的有用链接:http://www.agilent.com/find/pm_firmware该网站
尝试找到最新的fw并在仪器的支持页面中显示该版本。
不幸的是,它经常似乎找到一些其他软件并使用该版本号。
这个问题并不是功率计所特有的,网络团队也意识到了这一点。
在修复之前,请转到特定仪器的下载页面以查找最终信息。
以上来自于谷歌翻译
以下为原文
version A.01.09 is the current version as of today.
this note from the firmware download page might help explain the discrepancy you see between the agilent.com site and the meter itself:
Applicable for N1913A and N1914A power meters.
Version: A.01.09
Compatibility: EPM Series N1913A and N1914A power meters
Date: Sep 10, 2013
Please note that after the firmware is installed into the power meter an additional digit will be added to the firmware revision. The number added after the first letter in the firmware revision will designate the number of power sensor channels in the power meter. For example the A.01.05 firmware installed in a two channel N1914A will now be shown as A2.01.05 on the display of the power meter; installed in a one channel N1913A the firmware revision will be A1.01.05.
this is a useful link for current firmware for all Agilent power meters:
The website tries to find the latest fw and display that version in the support pages for an instrument. Unfortunately, it frequently seems to find some other software and use that version number instead. This problem isn't unique to power meters, and the web team is aware of it. Until it's fixed, go to the download page for a specific instrument to find the definitive info.
N1914A功率计。
以上来自于谷歌翻译
以下为原文
Version: A.01.09
Date: Sep 10, 2013
举报
