单片机学习小组
直播中
施敏
8年用户 227经验值
私信 关注
51单片机控制ST7920的液晶有些字不能显示
用51单片机控制ST7920的液晶,有些字显示不出来,请各位老大帮忙看看程序哪有问题
#include "reg52.h"
#include "intrins.h"
***it io_LCD12864_RS = P1^0 ;
***it io_LCD12864_RW = P1^1 ;
***it io_LCD12864_EN = P1^2 ;
#define io_LCD12864_DATAPORT P0
#define SET_DATA io_LCD12864_RS = 1 ;
#define SET_INC io_LCD12864_RS = 0 ;
#define SET_READ io_LCD12864_RW = 1 ;
#define SET_WRITE io_LCD12864_RW = 0 ;
#define SET_EN io_LCD12864_EN = 1 ;
#define CLR_EN io_LCD12864_EN = 0 ;
void v_Lcd12864CheckBusy_f( void ) //忙检测函数
unsigned int ntimeOut = 0 ;
SET_INC
SET_READ
CLR_EN
SET_EN
while( ( io_LCD12864_DATAPORT & 0x80 ) && ( ++nTimeOut != 0 ) ) ;
CLR_EN
SET_INC
SET_READ
void v_Lcd12864SendCmd_f( unsigned char byCmd ) //发送命令
v_Lcd12864CheckBusy_f() ;
SET_INC
SET_WRITE
CLR_EN
io_LCD12864_DATAPORT = byCmd ;
_nop_();
_nop_();
SET_EN
_nop_();
_nop_();
CLR_EN
SET_READ
SET_INC
void v_Lcd12864SendData_f( unsigned char byData ) //发送数据
SET_DATA
SET_WRITE
CLR_EN
io_LCD12864_DATAPORT = byData ;
_nop_();
_nop_();
SET_EN
_nop_();
_nop_();
CLR_EN
SET_READ
SET_INC
unsigned char LcdRdata(void)//读数据
unsigned char LcdData;
io_LCD12864_DATAPORT=0xff;
SET_READ
SET_DATA
SET_EN
_nop_();
    _nop_();
LcdData = io_LCD12864_DATAPORT;
    CLR_EN
return (LcdData);
void v_DelayMs_f( unsigned int nDelay ) //延时
unsigned int i ;
for( ; nDelay > 0 ; nDelay-- )
for( i = 125 ; i > 0 ; i-- ) ;
void v_Lcd12864Init_f( void ) //初始化
v_Lcd12864SendCmd_f( 0x30 ) ; //基本指令集
v_DelayMs_f( 50 ) ;
v_Lcd12864SendCmd_f( 0x01 ) ; //清屏
v_DelayMs_f( 50 ) ;
v_Lcd12864SendCmd_f( 0x06 ) ; //光标右移
v_DelayMs_f( 50 ) ;
v_Lcd12864SendCmd_f( 0x0c ) ; //开显示
void v_Lcd12864SetAddress_f( unsigned char x, y ) //地址转换
unsigned char byAddress ;
switch( y )
case 0 : byAddress = 0x80 + x ;
break;
case 1 : byAddress = 0x90 + x ;
break ;
case 2 : byAddress = 0x88 + x ;
break ;
case 3 : byAddress = 0x98 + x ;
break ;
default :
break ;
v_Lcd12864SendCmd_f( byAddress ) ;
void v_Lcd12864PutString_f( unsigned char x, unsigned char y, unsigned char *pData ) //任意位置显示内容
v_Lcd12864SetAddress_f( x, y ) ;
while( *pData != '' )
v_Lcd12864SendData_f( *pData++ );
void main( void )
v_Lcd12864Init_f() ;
v_Lcd12864PutString_f( 0,0, "杀戮为取红颜笑") ;
v_Lcd12864PutString_f( 0,1, "君子坦荡欲何求") ;
v_Lcd12864PutString_f( 0,2, "黑白风云谁是主") ;
v_Lcd12864PutString_f( 0,3, "旁人含笑看输赢") ;
while( 1 ) ;
回帖(6)
李一钰
2019-2-27 09:54:16
第二行单独显示试试~~换成其他字
举报
李晓欢
2019-2-27 10:31:42
放到第一行呢?君,过,能显示么?
举报
范潇潇
2019-2-27 10:50:37
那就奇怪了,呵呵.
举报
李波波
2019-2-27 11:09:38
我也很纳闷,找不出原因。对了,原子哥,你的豪华板什么时候出 啊
举报
更多回帖
